Browse Forums Flooring & Floor Covering 1 Sep 13, 2010 12:29 pm Hi there, I'm considering using solid teak wood flooring for our home in melbourne. However, i notice it's not very common in Australia as I can't seem to find many stockist carrying them. Anyone know the reason why? Or does anyone have any experience with teak flooring? Any recommendations good teak flooring suppliers would also be great! I know the price is pretty hefty but from what i heard the benefits of using teak is pretty impressive. We plan to have this home last for generations so we're looking to invest in materials that very durable, hence teak. Any inputs/thoughts would be really helpful. Re: Teak flooring 2Sep 13, 2010 12:56 pm Depends a bit on which Teak you are looking at, but given that they are imported rainforest timbers then their popularity has plummeted in recent years. For a local hardwood look at Turpentine, Spotted gum, Mahogany or Bloodwood. Re: Teak flooring 3Sep 13, 2010 1:06 pm namtrak Depends a bit on which Teak you are looking at, but given that they are imported rainforest timbers then their popularity has plummeted in recent years. For a local hardwood look at Turpentine, Spotted gum, Mahogany or Bloodwood. They're burmese teak....any negatives on that? Re: Teak flooring 4Sep 13, 2010 1:08 pm namtrak Depends a bit on which Teak you are looking at, but given that they are imported rainforest timbers then their popularity has plummeted in recent years. For a local hardwood look at Turpentine, Spotted gum, Mahogany or Bloodwood. Oh one more thing. I understand that teak because of it's natural oils are more resistant to infections, decay & wear & tear. Do the local hardwoods have the same or similar benefits? If they do, I would be keen to consider those as well. Thanks for your advice! Re: Teak flooring 5Sep 13, 2010 5:25 pm Can't really help you with that, if the timber is high in Tannins you do need to make allowance for that. Check the types of primer your product uses. Also if you need a termite resistant timber then look at Cypress flooring. Re: Teak flooring 6Sep 14, 2010 9:03 pm Hi, If you are interested in Teak flooring for your home, you can talk to us. We are manufacturers & distributors of Teak flooring sourced from plantation grown Teak in Java. We have a container arriving in Australia early October. The flooring is engineered for stability and has a 6mm face to last a lifetime. It comes in 4-5 widths 140mm, 180mm, 200mm, 220mm, 250mm. This is how it is installed as it was traditionally in the mixed width. The lengths are up to 2500mm. The face has a brushed grain and has been hand aged. It comes raw so you can stain it if you want and coat it with what ever finish you desire. If you would like any further info please contact Dean 0414974199 or www.floorwood.com.au info@floorwood.com.au 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6174 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15886 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6454 |
