Browse Forums Flooring & Floor Covering 1 Sep 03, 2010 9:25 am hey guys just after some advice was wondering if the chipboard floor will need a sand b4 the floating blackbutt floor is installed. A mate ex-carpet guy saw it and said yes, flooring guy said prob not (he hasnt seen it). Flooring guy even said the big hole ( that a fist or 2 can fit in ) should be ok. He seems to be more worried about the floor not being any more than 2mm out. He said the underlay is 2mm then the floating floor sits on top. Anyways, here are some pics. I desperately want to get my heating/cooling ducts cleaned after all the dusty work we have had done, but if we need a sand i will wait till that is done first. thanks ! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: pics : does floor need sanding b4 floating floor install 5Sep 03, 2010 4:23 pm There should be no problem at all as they use a thick adhesive these days they go over tiles as well so should be ok to go. Craig Re: pics : does floor need sanding b4 floating floor install 6Sep 22, 2010 8:51 am I'd be more interested to hear their opinion as to how much the cb subfloor can be safely sanded before it starts losing its structural properties. I'm told cb should not be sanded away "too much", which seems to be around mm but only at the edges My signature is distracting people from my wise posts ... Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3002 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 389 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15787 |
