Browse Forums Flooring & Floor Covering 1 Sep 02, 2010 10:00 pm After spending a few days at a holiday home with polished concrete floors, I 'd love to have them in our new place. My husband spoke with the builder and was advised that if we went for polished concrete, it would be about an ADDITIONAL $35K above the $24K which has already been allowed for our slab/footings. Sadly, if this is correct, there's no way we can get the concrete but I'm hoping there is another option. Just hoping to find out if this is something worth pursuing or not... TIA Re: Polished concrete flooring - does this sound right to yo 2Sep 02, 2010 10:05 pm I'd like to know more about your design. I will PM you my details Where you are coming from is where you are going to... Re: Polished concrete flooring - does this sound right to yo 4Sep 05, 2010 9:52 pm Would that be the increase in cost of going to 32mpa concrete over usual 20mpa? More details would be great, such as slab type, ground type, etc. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Polished concrete flooring - does this sound right to yo 5Sep 06, 2010 10:56 am Murphester ADDITIONAL $35K above the $24K which has already been allowed for our slab/footings Would that 35k include: -32mpa concrete in stead of 20mpa -color mix such as Boralstone Snowflake -polishing and finishing Does it also remove the need for flooring which would again reduce the cost. Re: Polished concrete flooring - does this sound right to yo 6Sep 06, 2010 3:41 pm Hmmm 20 to 32 mpa is about $14 cu mtr... so I think not. Also finishing concrete for a polished floor is less work than finishing for a standard floor. Though one does need to know what to look for when placing. The cost for the special mix is likely about double the cost of standard concrete. Hope this helps Where you are coming from is where you are going to... Re: Polished concrete flooring - does this sound right to yo 7Sep 06, 2010 5:02 pm onc_artisan Hmmm 20 to 32 mpa is about $14 cu mtr... so I think not. Also finishing concrete for a polished floor is less work than finishing for a standard floor. Though one does need to know what to look for when placing. The cost for the special mix is likely about double the cost of standard concrete. Hope this helps 20 to 32 is 14m3 but is that retail or trade...or builder marked up...this would be same as some people paying x$ extra for stone rather than laminate whilst Ceaserstone costs $350 a sqaure metre. Special mix doubling cost....is that $200 to $400 or $50 to $100? Not trying to justify the 35k, but could be a fair bit different between a 150 sqm house versus a 500 sqm house. Re: Polished concrete flooring - does this sound right to yo 8Sep 07, 2010 7:51 pm The rate is the same no matter what the area. ...and yes retail. Where you are coming from is where you are going to... Re: Polished concrete flooring - does this sound right to yo 9Sep 08, 2010 9:36 am onc_artisan The rate is the same no matter what the area. ...and yes retail. I think you missunderstood....not saying rate is cheaper for 500sqm as compared to 150sqm. I am saying 35k for a 500 sqm lay is more reasonable than 35k for a 150sqm lay. Re: Polished concrete flooring - does this sound right to yo 10Sep 08, 2010 8:29 pm Whilst that may be true it will never happen ...anyway enough time wasted on this thread Where you are coming from is where you are going to... They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5900 Hi We have a road close to our place and only an old flimsy wooden fence between us and the Neighbour closest to the road. Any ideas on a sound proof modular fence. Like… 0 7480 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31169 |
