Browse Forums Flooring & Floor Covering 1 Aug 17, 2010 8:36 am Hi Folks, I have a bit of a dilemah with my floorboards plan. I'm planning to lay floorboards in the entry hall, down the hall to the living areas and through the dining/kitchen areas. My issue is that the entry hall and the hall running into the living areas runs on a 'L' shape. I'm not sure what way to go with the floorboards. Obviously to make the most impact in the entry foyer I would want the floorboards running away from the door lengthways, but then when it gets to the end, if I stay in that direction I will have lots of short pieces running across ways in the other hall. I'm not really fussed what way they run in the living areas becuase it is such a big space. What options have people gone with for areas that run parallel to each other? Does anyone have photos of a change of direction in floorboards? Cheers Re: Direction to lay floorboards 2Aug 17, 2010 9:18 am is the other "end" bit of the hall that turns the corner longer than the entry bit? if not, I would be inclined to leave the long bits in the entry and have a small portion of short bits running across the hallway. I think it would look a bit piecemeal having them run different ways... I haven't seen a floor like this though so could be wrong. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Direction to lay floorboards 3Aug 17, 2010 9:31 am found a couple of pics on the net.... the first one I don't like so much, though it's not finished, it seems they have the boards changing direction and then changing direction AGAIN, I think this is too much... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ but this one I don't mind, looks a bit like parquetry they way they've done the corner, you can tell it's meant to be done like this, rather than looking like bits of floor were added or removed later... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31837 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4355 Hi All New to the forum and looking for some advice, has anyone else renovated an old miners cottage in or around Ballarat and been able to identify the flooring? We… 0 8775 |
