Browse Forums Flooring & Floor Covering 1 Aug 16, 2010 7:18 pm Hi All , Is there a height difference betwen the Solid timber 19mm on batons Vs Por tiles ? . My builder wants to know my Solid timber finished floor height before going in to construction . We had to raise the Kitchen kick board heights due to Por tiles but not sure what to do with the living areas . Thanks GFdo Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15904 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8302 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9591 |
