Browse Forums Flooring & Floor Covering 1 Aug 13, 2010 12:34 pm Hi, I know that most shop suggest to put a water resistance underlay is enough before laying a laminate floor. But really interested to know if someone has opinion, whether it'd better to seal the concrete with waterproofing agent first, just to make sure moisture doesn't go up? Or will this make things worse (not really sure if there's any unwanted side effect, but just wondering why not so many people wants to do that - apart from cost, obviously). Thanks. Re: Is it better to seal concrete floor before laying lamina 3Aug 13, 2010 4:54 pm Beg to differ^^ If the barrier is not stuck to the floor there will be a small air gap, if moisure comes from the slab it may go mouldy between the barrier and the slab... might be a small chance but for the cost of a few dollars a mtr it might be a good idea to seal. Even a cheap cement dressing would be good IMHO only. Where you are coming from is where you are going to... Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4327 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1931 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5185 |
