Browse Forums Flooring & Floor Covering 1 Aug 02, 2010 3:14 pm i just had a quote done for Laminate - Armstrong Forest Select for my lounge room (and bedroom if we can afford it) this is what the quote says: 39.60m @ $100p/m2 - $3,960 plus trims and taking up carpet i don't know but this seems like a lot - the laminate is much much better looking than what i expected but all the same it's come in at twice the price of having carpet put in the same areas Re: Is this a lot for laminate floorboards? 2Aug 02, 2010 4:20 pm Hi Kandrock I think it is very expensive we are getting bamboo installed for $110 a metre square laminate for the most expensive when I looked was $40 a sm plus instalation I would get a few extra quotes and maybe take the carpet up yourselves Soots viewtopic.php?f=31&t=31037 harvard 27 DFH signed contract 16th March 2010 slab down 1st June 2010 frame started 8th June 2010 trusses and frame finished 24th June 2010 tiles almost done 14th July 2010 Bricks started 14th July 2010 Plaster started 28th July 2010 Paint 25th August 2010 Re: Is this a lot for laminate floorboards? 3Aug 03, 2010 6:09 pm Hi, I also on similar situation with you and interested on similar products. What I got so far is: $49/sqm supplied only. I'm thinking to DIY, but I also asked that with installation (inc. underlay), they will cost me about $64-$69. Not including taking the carpet (as I don't need it) and the trim (as they'd need to come and have a look, but I believe it will be like $100-$200 additional for any trim/scotia I need). So, yes, $100/sqm seems to be a lot (not sure if we're comparing apple to apple here though Re: Is this a lot for laminate floorboards? 4Aug 04, 2010 6:26 am That sounds like a full RRP type of price, like full whack for everything - BUT maybe it includes floor leveling, your floor may need an Ardit 1st - and they have included it in the quote. A 2.2mtr long 12mm thick board should be say around $79 - $89 m2 fully installed (good underlay, scotia, trims all included). The full whack price though can be as high as 69 + 5 + 25 here in Melbourne so..... Where are you located ?? Re: Is this a lot for laminate floorboards? 6Aug 04, 2010 4:42 pm If you call Tony Mckosker at HN Fyshwick, tell him I sent you. Ask for Timber Impressions Long Boards. Tell him the pricing you have and that I promised you that he would smash it! He'll save you some money. TI Longboards are 2.26 mtrs long, 12.3 mm thick and have a 30 year warranty. 42 months IF is on now too that you could take advantage of. Cheers. Hi All New to the forum and looking for some advice, has anyone else renovated an old miners cottage in or around Ballarat and been able to identify the flooring? We… 0 8909 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 2165 Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4824 |
