Browse Forums Flooring & Floor Covering I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3344 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 414 just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue… 1 350 |
