I was going to nail in quads along the perimeter, but then it was suggested I could also use liquid nails instead. What do you think?
Thanks
Browse Forums Flooring & Floor Covering Re: Nail or Glue Quads 2Oct 25, 2007 3:24 pm br53, nail or liquid nails along the perimiter of what??? Re: Nail or Glue Quads 4Oct 25, 2007 3:51 pm I suppose that if you are gluing or nailing the flooring to the slab or whatever it is you are laying it on, the quad shouldn't need nailing too, should it? Not sure on that one, as we have not laid our floor yet....
There are plenty of people on here that will be able to advise you though. Re: Nail or Glue Quads 6Oct 25, 2007 8:52 pm Just use nails, much easier if you have to lift them off for some reason Re: Nail or Glue Quads 8Oct 25, 2007 10:29 pm Agreed with the last two replies, just stick to nails only. Glue would be quite messy and you will find that the walls are not dead straight so nailing will allow you to 'pull in' the quad as needed.
I would recommend that you pre-drill all the nail holes and have a good nail punch to punch the nails down. You can putty over the nails holes and stain the putty afterwards. If you haven't tought of about it, I found it easier to pre-stain all of the quad before installing. Good luck ask the surveyor for clarification would be the logical approach 1 20133 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8910 Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1551 |
