Browse Forums Flooring & Floor Covering 1 Jun 23, 2010 10:06 pm We've been getting quotes for supply and installation of 10mm solid Blackbutt overlay, laid over ply on concrete slab. Our preferred quote states it'll be laid on 9mm ply. I've read a number of posts here indicating that 12mm ply is more the norm. Can anyone check for me, whether the building code (BCA) refers to 10mm solid overlay and minimum ply thickness? I may be wrong but I think the 10mm solid overlay is relatively new?
Re: 10mm solid overlay - ply thickness? 2Jun 23, 2010 10:22 pm Hi Trinity, Do you know who is the manufacturer of this board? There is a brand new product called Ultra10 - are you referring to that? Mfr of Ultra10 instructs: The recommended plywood sub‐floor is structural grade, 15 mm thick and with a type A bond. Sheets are to be installed in a ‘brick’ pattern with a 6 mm gap between sheets and a 10 mm gap to internal and external walls. Sheets are to be staggered 900 mm so that from sheet to sheet, fixings do not line up. Plywood sheets are to be fixed to the slab with hand driven 50 mm long by 6.5 mm ‘Powers SPIKEs’ to manufacturer’s recommendations or equivalent. Twenty are required per 2400 mm x 1200 mm sheet, equally spaced and with the outer spikes 50 mm from the sheet edge. The head of the SPIKE is to be driven below the surface of the plywood. If 12 mm thick structural grade plywood, type A bond, is to be used for the sub‐floor, then the fixings to the slab are to be increased to 28 per sheet. ... Mechanical fixing combined with adhesive is necessary to achieve the required fixing performance. Floor fixing is to be a combination of adhesive and mechanical fixing. The adhesive may be a full bed applied to adhesive manufacturer’s instructions or beads of adhesive 6mm to 10mm in a zigzag pattern ensuring the pattern extends the full width of the board. ... My signature is distracting people from my wise posts ... Re: 10mm solid overlay - ply thickness? 5Jun 23, 2010 10:49 pm yes, we chose it to minimize differences in heights (ie between carpet, timber and tiles). Thanks for the info. I couldn't find that information on their website. Where did you find it? Re: 10mm solid overlay - ply thickness? 6Jun 24, 2010 5:14 pm Hurfords recommend it be laid over 12mm ply. It is fastened with 28mm staples and flooring adhesive. Re: 10mm solid overlay - ply thickness? 7Jul 23, 2010 6:46 am I'm actually looking at installing similar flooring over existing MDF. Is there still a requirement for the ply, or can this go straight on the existing floor? At present we have lino and carpet which will be coming up. Re: 10mm solid overlay - ply thickness? 8Jul 23, 2010 7:46 am Maybe you could ring the manufacturer directly and ask this ... is it Hurford's you're looking at?? If you don't know the manufacturer, ask your (re)seller who it is, or ask for the same info. My signature is distracting people from my wise posts ... Re: 10mm solid overlay - ply thickness? 9Jul 23, 2010 7:21 pm no you can't lay the flooring over MDF - who the hell put MDF down on the floor? Re: 10mm solid overlay flooring - Ultra 10 10Sep 16, 2010 9:17 pm Just popping back to post a sneak preview of our Ultra10 flooring in Blackbutt, for anyone interested. The timber has had two coats in the first three pics. The final Lobadur WS 2K Duo coat is yet to be applied. The 4th pic is to demonstrate the transition between the wood and the tiles (unsanded in this pic). We're very pleased with it so far. http://i562.photobucket.com/albums/ss69/sierra_099/IMG_1227.jpg http://i562.photobucket.com/albums/ss69/sierra_099/IMG_1233.jpg http://i562.photobucket.com/albums/ss69/sierra_099/IMG_1232.jpg http://i562.photobucket.com/albums/ss69/sierra_099/IMG_1177.jpg Re: 10mm solid overlay flooring - Ultra10 11Sep 17, 2010 7:34 am Looks fabulous! Was it just glued down to slab, or was it over some plywood? Have they levelled the slab beforehand? Do you have any high and low spots in your floor ? My signature is distracting people from my wise posts ... Re: Ultra10 - Blackbutt solid overlay floor COMPLETED! 12Sep 17, 2010 8:22 pm Thanks Lex! It was glued and secret nailed to 12mm ply. We were lucky that our slab was very level, so no self-leveling compound was required. It feels pretty good under foot. Final coat is complete. Ta daaaaaaaaaa..... http://i562.photobucket.com/albums/ss69/sierra_099/IMG_1243.jpg Skirtings now to be filled and painted. Re: Ultra10 - Blackbutt solid overlay floor COMPLETED! 14Oct 16, 2010 8:58 am Lovely floor Trinity. RF Build: viewtopic.php?f=38&t=34534 Flooring: viewtopic.php?f=7&t=39733 Chat: viewtopic.php?f=36&t=53303 Re: Ultra10 - Blackbutt solid overlay floor COMPLETED! 16Feb 23, 2011 10:25 am Hello Trinity, I was researching Boral Silkwood Blackbutt when I came across your post and the pictures of your finished floor. It looks absolutely marvellous! I understand from your comments that the floor was glued and secret nailed. Is this directly onto concrete slab or did you install a plywood over the slab first? Also, now that it's been 5 months since it was laid, has it performed to your expectations? I was keen on Silkwood but now am leaning towards solid strips. Any comments and tips will be appreciated. cheers Re: Ultra10 - Blackbutt solid overlay floor COMPLETED! 17Feb 23, 2011 10:33 am Gorgeous! Was ply also glued to the concrete? Or just nailed? Re: Ultra10 - Blackbutt solid overlay floor COMPLETED! 18Feb 28, 2011 9:16 pm Thanks Oldrocker and blueblueblue. Five months on and we're still thrilled with the floor! Yes, the Ultra 10 was glued and secret nailed to the structural grade 12mm ply. The ply was mechanically fixed to the slab with nail/bolts(?), no glue, as there is a plastic membrane between the ply and the slab. It feels very firm/solid to walk on. No signs of gaps, splitting or warping whatsover, so far. So easy to keep clean. My only complaint is a few short dark hairs I've found trapped under the Lobadur finish Lucky only the cleaning lady (moi!) sees them. Re: Ultra10 - Blackbutt solid overlay floor COMPLETED! 19Mar 03, 2011 1:06 am I must say that your blackbutt floor looks great!!! Love the fact that there is not much black vein like you get with marri, And this is from a person who just sell Bamboo Flooring LOL!!! Any advice on a builder in NSW who is demanding an extra 22000k after the house is completed and contract paid in full .Standard HIA contract. Never received a variation.… 0 20515 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15908 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 |
