Browse Forums Flooring & Floor Covering 1 Jun 07, 2010 7:44 pm Hi Guys, We are in process of buying/laying tiles and have an idea of a laying design but need your advice please!! -- Basically i want 300x600 tiles and lay them in a 600x600 pattern. Here is an image i did in mspaint Do you guys think this will look good? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [b]Contract signed 3rd May --> Handover mid FEB Re: Tile laying options 300x600 2Jun 07, 2010 11:21 pm i think it depends on where it is going. I believe that it will look like traditional parquet flooring pattern. I used to sell this for a living and the one thing i can tell you is that your floor will take the focus from most of the things around it. If this is the purpose then i think it will look fantastic. The pattern abserlutley demands attention and draws focus be careful if this is not what you want. https://forum.homeone.com.au/viewtopic.php?f=36&t=37134 THE THREAD https://forum.homeone.com.au/viewtopic.php?f=31&t=35962 THE BLOG! http://pedrosinspiredbeauty.blogspot.com/ BRICKS BRICKS ARE FINISHED... ROOF STARTS TODAY 03/02/2011!. Re: Tile laying options 300x600 3Jun 07, 2010 11:32 pm Hi dvs_dk, Do you have a picture of the tiles, and where are they going to be laid? If they're a patterned tile I wouldn't recommend laying them in a basket-weave fashion over a large area - it could look very 'busy'. Re: Tile laying options 300x600 4Jun 08, 2010 9:59 am Hi, Depending on the tile, this could cause a problem when laying them. The length of a tile is 600, opposite 2 x 300 + one grout joint = 602 or whatever. If you don't trim tiles, the only way around that is to have grout joints which vary in width. It won't be much, a millimetre or so, but it could be obvious. Cheers Re: Tile laying options 300x600 5Jun 08, 2010 11:09 am I think GeoffW1 makes a good point ^ have you talked it over with your tile layer? I would also like to see pics of the actual tile. if it is a beautiful tile in itself then it will look gorgeous no matter which way its laid. a brick pattern could look good too, perhaps without being as attention-demanding as the parquet style. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Tile laying options 300x600 6Jun 08, 2010 2:45 pm Thanks for the responses. GeoffW1 - that is a really good point - something that hasn’t even crossed my mind - and no, I haven’t spoken to our tiler yet. The tile itself is beautiful and we saw it laid this way in a display home which looks amazing however feel that it will be too much and possibly something i will get over. I am planning on laying the tiles throughout the hallway and into a large open space at the rear of home. The majority of the hallway is 1.2m wide (except the entry which is about 2m wide. The open living/kitchen/dining space to the rear of the home is large approx 8x8m + 6x6m for the dining area. Here are the images of the tile: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [b]Contract signed 3rd May --> Handover mid FEB I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2371 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4637 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12158 |
