Browse Forums Flooring & Floor Covering Re: Has any one used Cape Sunrise from the Solutions Range?? 2May 15, 2010 6:34 pm Sounds like a Carpet Call name ?? I haven't heard of it. Sorry. When they say solutions range, make sure it's an SDN not an SDP !!! All polypropylene is solution dyed and nylon can be solution dyed. They get marketed thesedays under a generic Solution Dyed catergory. Big difference between them though!!! It's probably an SDN, just check and make sure Re: Has any one used Cape Sunrise from the Solutions Range?? 4May 15, 2010 8:26 pm Cool. Good luck. I am sure it will be great. SDN's are generally pretty good (as in there are not too many nasty ones on the market). In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7745 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3141 4 14257 |
