Browse Forums Flooring & Floor Covering Re: Skirting on b4 or after carpet gets laid?? 5Apr 13, 2010 11:06 am Definatly before. Usually they are painted before the carpet goes down and they will get knocked around a little from the carpet layers which is a standard thing but are then touched up by the painter afterwards. Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Skirting on b4 or after carpet gets laid?? 6Apr 13, 2010 11:09 am I don't know about every house, but we are building now, and the skirting has been done, and the carpet still isn't in. From reading the previous post, this seems to be the norm. When doing a new build I have been told that the carpet is one of the last things to be done. Re: Skirting on b4 or after carpet gets laid?? 7Apr 13, 2010 11:15 am A good layer will install carpets without damage to skirtings. But having said that, some carpets can be a mongrel to work with and even a good layer might cause some marks or knocks here & there. But that is the layers' responsibility to fix, so shouldn't be your worry. Inspect all skirtings before the layer goes, and make sure there's no marks first. Then inspect after the carpets are installed and if any probs, let them know. Ash. Re: Skirting on b4 or after carpet gets laid?? 8Apr 13, 2010 11:27 am When we built this place, we go the skirtings "tacked" on - and then after the carpet was laid they were installed properly...and it was perfect. My house and my rants.... - viewtopic.php?f=31&t=26937 We are in!!!...and still unpacking. Thankfully there are always Tim Tams Re: Skirting on b4 or after carpet gets laid?? 9Apr 15, 2010 6:40 pm mpcj When we built this place, we go the skirtings "tacked" on - and then after the carpet was laid they were installed properly...and it was perfect. There is no need to do this. The problem can arise that when the skirting is finally secured, that it can pull away from the carpet slightly. Far better to have it full fixed in place to start with. IMHO Re: Skirting on b4 or after carpet gets laid?? 10Apr 15, 2010 6:58 pm I agree with Mark S have it fully fixed to start with. Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Skirting on b4 or after carpet gets laid?? 11Apr 15, 2010 11:03 pm Fair call. It worked for us...but then again...just lucky I guess... My house and my rants.... - viewtopic.php?f=31&t=26937 We are in!!!...and still unpacking. Thankfully there are always Tim Tams Re: Skirting on b4 or after carpet gets laid?? 13Apr 16, 2010 4:15 pm As a fixing carpenter I can tell you that fixing and painting the skirting before the carpet and lifting it about 12mm (depending on the thickness of carpet) off the slab/floor is best. Then when the carpets go in they get tucked under the skiting. This gives the neatest look and the full height of your skirting is visible. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Skirting on b4 or after carpet gets laid?? 14Apr 16, 2010 8:45 pm chippy As a fixing carpenter I can tell you that fixing and painting the skirting before the carpet and lifting it about 12mm (depending on the thickness of carpet) off the slab/floor is best. Then when the carpets go in they get tucked under the skiting. This gives the neatest look and the full height of your skirting is visible. I have no problem with this [ I use a PS ] , but if the carpet is just kicked in, it is more likely to come off the smoothedge in the future. When the skirting is to the floor, the carpet is held better, as it is jammed between smoothedge and skirting. It will help it stay on the pins. I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8148 Joe Apologies for the delay in getting back to you. If you haven't sorted this already you need to caulk this gap. Not sure where you are but if you are in Sydney I can… 5 4373 7 3021 |
