Browse Forums Flooring & Floor Covering 1 Apr 05, 2010 5:13 pm Does anyone know how the amount of timber flooring needed for a job is calculated? We've got two quotes to put timber flooring in and they vary a lot in the square metre amount needed. Our house is 277 square metres (not including garage or alfresco) and the theatre, laundry and both bathrooms are not having timber flooring. Quote 1 came up with 234 square metres plus wastage of 7%. Quote 2 came up with 291 square metres including wastage. I'm intrigued that quote 2 claims we need more timber than the entire house! The house is also pretty square, there are no angled walls or anything like that, either. Re: Calculating amount of timber flooring required? 3Apr 05, 2010 6:36 pm Are you doing laundry and bathrooms. Looks like they are quoting to much. Why dont take the time and work it out you. I had the same issue when it came to sand my floors. Sundenly I had 130 squaremeter where I only bought around 115 m2 in actual timber. I then told the next guy that I spent 30 minute wokring out my area and i got 105 and Let me know if you get any thing different? Guess what hey got the same. Re: Calculating amount of timber flooring required? 4Apr 05, 2010 9:35 pm Just get a tape measure and measure it yourself, only about 5 minutes work. 5% would be heaps of excess for a job that size. Failing that, do you have plans? Re: Calculating amount of timber flooring required? 5Apr 05, 2010 10:28 pm We have measured it ourselves - it was the first thing we did so that we had some idea before we went into the timber places. I was just wondering if there was some other method the shops used given the amount the second quote came up with exceeded the house size. Re: Calculating amount of timber flooring required? 6Apr 06, 2010 7:09 am Nope, no other method. Should be the floor size of the area to be floored plus 5% Some guys just look at a floor and guess, I'm not good enough for that yet Re: Calculating amount of timber flooring required? 8Apr 06, 2010 2:18 pm Yeh your right Borg, when I measure up a job myself. For sanding - I round down to the nearest .1, for installations I round up to the nearest .1 However whenever I use subbies for a job they are always a lot more 'expansive' with their measurements. Re: Calculating amount of timber flooring required? 9Jun 15, 2010 9:52 pm Another thing that happens is some less-than-reputable reseller advertise a product for say $10 and tell you that you need 20 metres, and the next guy quotes you $20 a metre and you only need 10 metres. It's an old trick that some people employ. The other thing that is becoming more and more common, is where a customer comes to see me and says they need say 40 metres of carpet. They have had it measured already. I price them for 40 metres and they have a heart attack. Then I ask to measure it and find it's really only 30 metres, and when I re-work the price I am less expensive. The first person is hoping all the other quotes they got are so much more that they will come back - but they are misleading the customer! You need a retailer who sits down and explains everything from start to finish in a transparent, professional manner, then you'll be right. Ask as many questions and be involved as much as you can. If you like call me, I'll work out your metres and tell you 100% spot on what you need ( if you know the pack size, that has a small impact). WOW you are spot on. Those trees are on council land and have already caused significant problems. A few years ago the builder had to come back and install a root barrier… 7 2373 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15886 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5423 |
