Hello all,
We're going to be getting solid timber flooring through our hallway/kitchen/dining and family areas, with the rest of the house to be carpeted. The timber people have advised that the skirting boards will need to be removed then refitted and also that the kicker around the bottom of the kitchen cupboards will need to be raised 30mm.
My question is this - if the skirting boards are replaced 30mm higher, they will be out of line with the rest of the skirting boards! What do others recommend? Has anyone else encountered this? I believe an alternative is to not remove them at all and to put an additional skirting where the timber joins. Would this look ok or a bit odd?
Any thoughts please?
Thanks,
Pootle
