Does anyone know if it's possible to remove tiles laid with adhesive directly over a yellowtongue floor? If so, is it a difficult thing to do, and would it be best to get proffessionals in to do it? Any reccomendations?
Thanks
Browse Forums Flooring & Floor Covering 1 Sep 03, 2007 7:49 pm HI everyone,
Does anyone know if it's possible to remove tiles laid with adhesive directly over a yellowtongue floor? If so, is it a difficult thing to do, and would it be best to get proffessionals in to do it? Any reccomendations? Thanks ![]() Re: Removal of floor tiles 2Sep 03, 2007 10:30 pm Get a quote or two.
Decide - Do I want to save that much money for the effort - If yes - set a plan then go for it. Then you can work out how hard they are to remove - and if it really is too hard - and I mean really to hard. Then call in the pros if need be. But at least you will know what it's like. Steve Re: Removal of floor tiles 3Sep 03, 2007 10:44 pm This is hard work and requires a good shovel and lots of muscle!
Meaning you have to lift and ply the lot off the floor, while trying not to damage the sub surface…timber! I know a lot of people who have done it, and I can tell you, they say they will never do it again! Do as Steve has said get a quote from a flooring guy, spend your time doing other EASIER jobs. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Removal of floor tiles 4Sep 04, 2007 12:44 pm Thanks Michelle and Steve - so it seems it can be done???? Now I'm just a bit worried about damaging the yellowtongue subfloor. What sort of companies do I need to look for to get the work done - looked for 'tile removers' in the yellow pages but couldn't see anything. Another idea guys - can floating floors be laid OVER tiles, to save ripping them up?
Thanks so much again ![]() Re: Removal of floor tiles 5Sep 04, 2007 12:51 pm Re Who - Any builder will rip them up for you - just look for the local builders and alterations guys.
Re over the top of tiles - Hmm - Can be done - I'd ask the floating floor guys and see what they say. But you have to be aware all the doors need to be re-cut and the skirting boards etc will alsl be an issue as the floor will be a good bit higher than it is now. Where removing the tiles drops it down before you add on top of it again. Steve Re: Removal of floor tiles 6Sep 04, 2007 2:34 pm It will be almost impossible to do without damaging the yellow tongue. Its pretty poor form in the first place for them to be ahdered to yellow tongue - there should have been a sheet of ceramic tile underlay between.
At about $35 per sheet I'd rip the lot up and replace the yellow tongue - a lot less tedious. There is every chance the yellow tongue will have 'swelling' where it has absorbed moisture from the adhesive anyway. Re: Removal of floor tiles 7Sep 05, 2007 5:07 pm ![]() It will be almost impossible to do without damaging the yellow tongue. Its pretty poor form in the first place for them to be ahdered to yellow tongue - there should have been a sheet of ceramic tile underlay between. At about $35 per sheet I'd rip the lot up and replace the yellow tongue - a lot less tedious. There is every chance the yellow tongue will have 'swelling' where it has absorbed moisture from the adhesive anyway. Luke, that terrifies me ![]() ![]() What do you think of the other idea, of putting a floating floor on top - height difference wouldn't worry me too much in that case Eimaj Re: Removal of floor tiles 8Sep 13, 2007 9:33 pm Were the skirtings fitted before or after the tiles were laid? Provided the tiles are nice and flat there probably isn't a problem apart from the height - I'd email the manufacturer. Re: Removal of floor tiles 9Sep 14, 2007 5:03 pm Thanks Luke - skirtings were there before the tiles (which are very flat, no cracks or anything). Do you see any problems with this? From what I see on other threads, a quad-type edging can be put around the skirtings (this look doesn't worry me).
I would be worreid about removing the entire floor because we have a woodheater, as well as ducted heating under the floor. Thanks again for your help, Luke ![]() Re: Removal of floor tiles 10Sep 16, 2007 7:47 pm I have no idea whether or not its safe to use the under floor heating under a floating floor, but I imagine it would be useless if you add another layer on top of the surface. The heather may also cause moisture problems as you will have a layer of thick plastic under the floating floor.
How tall is the skirting? You may almost have no skirting by the time the floor is put in. Re: Removal of floor tiles 11Sep 17, 2007 2:37 pm Hi Luke the skirtings are about 10cm deep. Not sure if I explained the heating properly - it's normal gas ducted heating, with about 4 vents in the floor area. I thought the holes for the vents would be ok if they are repeated on the floating floor.
Thanks again ![]() Re: Removal of floor tiles 14Sep 25, 2007 1:31 pm Shouldn't be a problem - I'd speak to the manufacturer of whichever floor your looking at putting down about it and the tiles. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 3262 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 1804 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 3339 ![]() |
