Browse Forums Flooring & Floor Covering 1 Aug 25, 2007 4:16 pm HI everyone,
I'm considering getting a laminate floating floor. Is there anyone who is happy with theirs, and can recommend it? Or has anyone had bad experiences or any warnings? Do they show indentations from furniture or stiletto heels like timber? Any advice appreciated!!! Thanks Eimaj Re: Laminate floating floor - are you happy with it? 2Aug 26, 2007 6:26 pm Personaly I hate the thin sound of them as you walk across them.
but re dent etc - any timber floor will mark they are not like tiles. But 4 me that's part of their "warmth and character" So you either like it or you don;t This link will give you some tips. http://www.timber.org.au/menu.asp?id=101 The timber flooring manual at 3mb is a good read. Steve Re: Laminate floating floor - are you happy with it? 4Aug 27, 2007 3:45 pm I have had my floating floor down a month now.
I love love the look of the timber floors. But I sweep every day and see dust and pet hair straight away. I have 2 kids and think i might need a mat under the kitchen table. The builder actually upgraded our flooring to a better (thicker) one due to unavailable product which I think was luck as I have noticed some splinters in the wood of this one and may have been worse with a lower grade. I'm not sure if this is normal or not but when sweeping things can get stuck in these splinters and are hard to get out. Also the laid wood around edges and these also splinter at the corners. Re: Laminate floating floor - are you happy with it? 7Sep 01, 2007 6:18 pm (I'm not sure if this is normal or not but when sweeping things can get stuck in these splinters and are hard to get out. )
That’s a first…. I haven’t heard of that happening before. My advice to anyone thinking of “tongue and groove” flooring is to get an expensive one. The warranty is better and so is the quality. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Laminate floating floor - are you happy with it? 8Sep 01, 2007 10:46 pm We have laminate boards but have upgraded from the white foam underlay that seems to come free with all laminate boards in WA to a thicker rubber acoustic underlay. if that helps seems to have gotten ride of that click clack noise on the ones they had down in the show room Re: Laminate floating floor - are you happy with it? 9Sep 05, 2007 6:19 pm off2theburbs We have laminate boards but have upgraded from the white foam underlay that seems to come free with all laminate boards in WA to a thicker rubber acoustic underlay. if that helps seems to have gotten ride of that click clack noise on the ones they had down in the show room Good to know, regarding the underlay. Are you happy with them off2theburbs, in terms of wear? What brand are they? Thanks for the response - Eimaj Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3003 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 399 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6153 |
