Browse Forums Flooring & Floor Covering 1 Feb 24, 2010 9:10 am When we bought this house it already had a damaged floating floor. Just the usual light scratches but in some areas it almost looks like the floor has be rubbed with a scourer. We need to sell will we be able to get these boards looking ok again? It is dark timber so very noticable. Could someone point me in the right direction? Re: Fixing scuffed and scratched floating floor 2Feb 24, 2010 9:25 am I would suggest to redo the floor. If its a floating laminate then it would be simple to remove the baseboard, take up the good stuff (keep it organized)until you reach the scratched/damaged boards and replace them, then simply snap together the sheets that you just removed. If the damaged boards are all full pieces and the room is approximately 15'x15' it should take less then an hour to do. $200 Canadian Cash-BACK Mortgage - Visit HERE for promotion coupon and details! Canadian House Fix, Repair and Renovation - Follow a blog about my personal renovation experiences. Re: Fixing scuffed and scratched floating floor 3Feb 24, 2010 10:19 am My concern here is getting a board to match. It is a Henely built home they installed the floor about 2 years ago. Would it be easily matched. (starts thinking about rugs.......... ) Re: Fixing scuffed and scratched floating floor 4Feb 24, 2010 7:48 pm If u are after a quick fix, Boral have a laquer in a can stuff. Have not tried it, but it might do the trick depending on gloss level of existing stuff. Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3002 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 389 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11561 |
