Browse Forums Flooring & Floor Covering Re: Scratches in Bamboo flooring 2Feb 22, 2010 5:42 pm Mrs P We have some scratches in our bamboo floors courtesy of my dog. Is there any way I can help disguise them and fix them up a bit. Thanks If they are only small white scratches which will just be the polish try some furniture polish they will help hide them good luck. Re: Scratches in Bamboo flooring 4Mar 07, 2010 9:23 pm Hi, I was wondering how you find the bamboo flooring. We are tossing up whether to go with bamboo flooring and the quick step laminate flooring. Whilst the laminate flooring is within our budget, I dont want to regret our decision. Are there different quality bamboo flooring products around? IF so can anyone recommend a good one? Cheers and thanks KT KT Re: Scratches in Bamboo flooring 5Mar 08, 2010 1:06 am hello Most of the time when you scratches a bamboo floor its usually the surface coat you are scratching and comes up in a white colour. What you can do is use a marker pen that is the nearest colour simply colour the scratch and then lick your finger and rub it in. Problem solved marcus Re: Scratches in Bamboo flooring 6Mar 08, 2010 9:04 am ktspruce Hi, I was wondering how you find the bamboo flooring. We are tossing up whether to go with bamboo flooring and the quick step laminate flooring. Whilst the laminate flooring is within our budget, I dont want to regret our decision. Are there different quality bamboo flooring products around? IF so can anyone recommend a good one? KT we have chosen to go with Quickstep laminate too, and from what we have read it's pretty much equal in terms of durability and hardness to the bamboo. The drawback is that you can't strip, sand and refinish if you get major cracks - you can, however, replace a board. Search these forums for keyword Quickstep - there are people who have had dogs, kids and stilettos with it and no problems.It's spoken very highly of. Re: Scratches in Bamboo flooring 7Jul 29, 2016 12:45 am If it is strand or natural bamboo flooring, you could go ahead and refinish them. Consult with your expert and apply a good finishing coat over your bamboo flooring which protects in from further scratches Founder of Floorfurnishings.com, a blog that provides home owners guidance on the different types of flooring to choose from. Re: Scratches in Bamboo flooring 8Aug 02, 2016 2:37 pm any bamboo flooring shouldnt be sanded again, only recoating is allowed as the surface will be as raw as sandpaper after sanded. 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6495 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16310 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6785 |
