Browse Forums Flooring & Floor Covering 1 Jan 19, 2010 9:10 pm hi everyone, we are in the middle of designing our home and plan on going for polished concrete in the living areas. we have a north facing living area and we plan on using the thermal mass in winter to keep us warm and cool in summer. we want to go with the full option - grinding with a hardener, then polishing. not just a grind and seal. my first question... if we do this do we still need to apply some sort of sealer to protect against stains etc? and my second... how prone is this type of floor to damage - through normal wear and tear, scratches, staining etc? thanks in advance... Re: Polished concrete - how well does it hold up? 2Jan 19, 2010 10:49 pm Hmmm... so who grinds and seals only? That sounds a bit cheap @rsed to me, not polished concrete at all. The practice is to grind, grout, densify, hone, polish, then WE use a special wax. Where you are coming from is where you are going to... Re: Polished concrete - how well does it hold up? 3Jan 28, 2010 1:33 pm Jason, Quote: if we do this do we still need to apply some sort of sealer to protect against stains etc? If is always advisable to install an impregnator at the end of a polished concrete project. Whist polished concrete done in a method as such as Hiperfloor will provide extremely stain resistant floors, an impregnator will guarantee it. An impregnator only needs to be applied once, and is not a topical product. If applied correctly it should last around 20 years in a domestic situation. Quote: how prone is this type of floor to damage - through normal wear and tear, scratches, staining etc? We have done accelerated wear testing on our floors through the CSIRO, and they were amazed at the results. The process we provide turns concrete into a highly abrasive resistant floor, it is very very very difficult to scratch (dragging a chair will not damage the floor), it is highly resistant to staining from fats and oils, but like all things, it can still be effected by acids. I hope this helps. Regards, Ben Vander Veen PROGRIND AUSTRALIA Maintenance Free Polished Concrete, without coatings! www.progrind.com.au yes it does, you've just not understood it. theres a difference. 4 5322 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9009 Finally got the Soakwell at my house sucked out. Now I’m looking for ideas on how to hide it as it’s a bit of an eye sore. I’m thinking I’d like to turf over the… 0 3273 |
