Browse Forums Flooring & Floor Covering Re: How do I remove blood from carpet? 2Jan 04, 2010 4:48 pm Judie Need help. There is animal blood on my pure wool carpet. I haven't tried to treat it yet - it's only been there for around 2 hrs or so. Thanks. Judie What happened Judie I think ash will have all the answers for you Building with Homebuyers Centre El Questro! My building thread..viewtopic.php?f=31&t=19421 Brickies started 5/10 Re: How do I remove blood from carpet? 3Jan 04, 2010 4:49 pm As long as you haven't killed anyone Judie!!! Here are a couple of links I found: http://www.essortment.com/home/removebloodcar_skku.htm http://www.essortment.com/home/bloodstainscar_sayj.htm Re: How do I remove blood from carpet? 4Jan 04, 2010 6:19 pm lynnebin1968 Judie Need help. There is animal blood on my pure wool carpet. I haven't tried to treat it yet - it's only been there for around 2 hrs or so. Thanks. Judie What happened Judie I think ash will have all the answers for you Unfortunately, one of the cats found a baby blue-tongue I've blotted with cold water and it's looking pretty good. The carpet is charcoal though, so I'm not sure that I got it all out. Judie Re: How do I remove blood from carpet? 5Jan 04, 2010 7:31 pm I thought animal sacrifices were only on full moons. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: How do I remove blood from carpet? 6Jan 04, 2010 7:35 pm Judie lynnebin1968 Judie Need help. There is animal blood on my pure wool carpet. I haven't tried to treat it yet - it's only been there for around 2 hrs or so. Thanks. Judie What happened Judie I think ash will have all the answers for you Unfortunately, one of the cats found a baby blue-tongue I've blotted with cold water and it's looking pretty good. The carpet is charcoal though, so I'm not sure that I got it all out. Judie Ohhh well I am happy it wasn't your little fur babies but sad for the lizard too Thank god the carpet is charcoal, I think it will be fine as long as you put the water on it before it had time to stain. Building with Homebuyers Centre El Questro! My building thread..viewtopic.php?f=31&t=19421 Brickies started 5/10 Re: How do I remove blood from carpet? 7Jan 05, 2010 12:28 am Hi Judie, How did the blood contact the carpet? Normally, blood will not penetrate far into the wool carpet, as the surface tension and other characteristics of the wool fibres keep it very much on the surface. So if fresh, it can often be removed quite easily with a damp cotton flanel, nappy or towel. Avoid overwetting though. Some Woolsafe Approved spot cleaner would be good to use, but DON'T apply it to the blood. Apply a little to the cotton nappy, and blot. This way the blood is drawn up and absorbed into the nappy. Work carefully. If you are not sure where remaining spots are, you can spray a light mist of hydrogen peroxide (no stronger than 3%) over the area, and you will see a reaction if it contacts blood. Then you can spot clean the blood. NO rubbing or scrubbing of the carpet. Just gentle blotting without overwetting. Call me if you have a prob. If there is a larger area of blood pooled, it is best to get in a professional. Ash. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6131 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12069 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7228 |
