But remember you will need to give it a tickle up now and then
probably take 10-20 minutes a week if your house is less than 250sq mtrs
and use a table spoon of wax lemon scented of course
Well unless you like teatree, or another essential oil
Browse Forums Flooring & Floor Covering Re: Polished Concrete Floors for Living Areas. Good Idea? 101Feb 12, 2010 6:04 pm Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 103Feb 12, 2010 8:28 pm Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 105Feb 13, 2010 8:21 pm 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ Re: Polished Concrete Floors for Living Areas. Good Idea? 106Feb 13, 2010 8:36 pm Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 107Feb 14, 2010 2:39 pm Regards, Ben Vander Veen PROGRIND AUSTRALIA Maintenance Free Polished Concrete, without coatings! www.progrind.com.au Re: Polished Concrete Floors for Living Areas. Good Idea? 108Feb 14, 2010 2:41 pm Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 109Feb 14, 2010 5:00 pm terrific thread... in perth, chasing polished concreting flooring for 80sqm just about to have handover, so would like to know approx costs, recommendations To suit a lot of brown/mocha cupboards/stainless steel kitchen gear white walls. Re: Polished Concrete Floors for Living Areas. Good Idea? 110Feb 14, 2010 5:16 pm stockt12 - Polished concrete is normally done in 2 stages, 1. After the slab is poured using a mix designed for polished concrete(ie 32mpa and usually with a blend of stones[aggregate-a selection] prior to the placement) called first stage grinding. 2. After the major building work has been done but usually before plaster/gyprock and second fix. If you haven't planned for this stage then you will have issues to deal with. Onc Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 111Feb 14, 2010 5:42 pm thank you for the super quick reply... so no polished concrete for me then... will attempt to do it with the next build this year what should i be budgeting for in terms of both stages? Re: Polished Concrete Floors for Living Areas. Good Idea? 112Feb 14, 2010 5:56 pm Well, first of all I must add that you still can have polished concrete or honed. However, the level of sheen will be in direct relationship to the slab mix and placement. Also it will be grey, likely with grey stones(bluemetal) which I think looks fine. .. and you could stain it. The cement and sand is the bit that refuses to polish if the MPA is not high enough or water is added to the mix during placement and the cure technique. Now for the next one, the things to consider are the areas you want polished. The colour you want? and whether the builder will allow it? The cost is more than normal grey but too wide a price variation to give you an all up price without knowing your choices. The cost to polish is around $100+ sq mtr. Hope that helps Onc Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 113Feb 14, 2010 6:08 pm ahhh my apologies i would still like to do it for this place, an area of approx 80squares. i have contacted people in perth about quoting up for it etc... without any luck, so if you could post some contacts that would be fantastic. for the next one, there is a 'sparkly' quartz looking design that i saw previously.. when my mind comes back from its weekend getaway, i will try and find a link to the pic Re: Polished Concrete Floors for Living Areas. Good Idea? 114Feb 14, 2010 6:33 pm onc_artisan OIC So by low end you mean there is no margin so you don't do it, or you don't know about it so therefore it is not something you do? It's prob a chat to have over a beer than in a forum Onc, then we can chat about all the different methods of polishing concrete Regards, Ben Vander Veen PROGRIND AUSTRALIA Maintenance Free Polished Concrete, without coatings! www.progrind.com.au Re: Polished Concrete Floors for Living Areas. Good Idea? 115Feb 14, 2010 6:34 pm A contact number is in my siggy line. But I will PM you as well. Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 116Feb 14, 2010 6:36 pm stockt12 ahhh my apologies i would still like to do it for this place, an area of approx 80squares. i have contacted people in perth about quoting up for it etc... without any luck, so if you could post some contacts that would be fantastic. for the next one, there is a 'sparkly' quartz looking design that i saw previously.. when my mind comes back from its weekend getaway, i will try and find a link to the pic Stockt, Try these guys: the polished concrete specialists Google is your friend Regards, Ben Vander Veen PROGRIND AUSTRALIA Maintenance Free Polished Concrete, without coatings! www.progrind.com.au Re: Polished Concrete Floors for Living Areas. Good Idea? 117Feb 14, 2010 6:41 pm I drink rum Ben... But I thought you guys were national Just wondering why you would be openly advertising my opposition. You should know open advertising is done only by legit advertisers Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 118Feb 14, 2010 6:50 pm onc_artisan I drink rum Ben... But I thought you guys were national Just wondering why you would be openly advertising my opposition. You should know open advertising is done only by legit advertisers Rum is good too. We only operate commercially at a national level, Residential is just NSW and VIC where we have our offices. As and advertiser here I cannot see the issue with someone asking for a reference and having one provided? Its not like they've logged in and plugged themself, then all those threads like "need a good tiler in Melbourne" would have to get closed down? But lets not digress from the thread hey? Regards, Ben Vander Veen PROGRIND AUSTRALIA Maintenance Free Polished Concrete, without coatings! www.progrind.com.au Re: Polished Concrete Floors for Living Areas. Good Idea? 119Feb 14, 2010 7:10 pm Agreed, however, If a phone number is placed in a post it is removed. It is against the 'Terms of use' surely you would be unhappy if someone posted the name of your opposition with their details Where you are coming from is where you are going to... Re: Polished Concrete Floors for Living Areas. Good Idea? 120Feb 14, 2010 8:11 pm Hey Onc and Ben, Hope I don't interfere with your banter here I have been enjoying your discussion Onc - the photo's you posted look great, good enough to convince me to consider concrete again! But - if polished (or honed) concrete does in fact crack, how do you repair it? And once repaired, is it still visable? Of course it would be preferable to think that if it was done "properly" it wouldn't crack, but I'm assuming there can never be a guarantee? Building on an acre in Macedon ......one day. 3 5771 You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4952 |
