Browse Forums Flooring & Floor Covering Re: floor boards question - I'm so dissappointed 12Dec 14, 2009 11:45 am Dollar Sometimes depending on the type of timber used means that there may be parts that are raised but this is more likely due to the density of the wood or the poor laying techniques. Nothing to do with it. If the substrate is out the floor will be out. To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 393 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1933 |
