Browse Forums Flooring & Floor Covering 1 Nov 20, 2009 8:30 pm Hi Everyone...would love to know if these quotes i've received are reasonable... I'll quote all the information i've been given hope this helps. Jarrah prime grade 80x19 for 86m2 Installation includes 1.seal the concrete slab 2.install 15mm plywood and fix to slab with 50mm spikes and timber floor adhesive 3 flooring installed on plywood and fixed with timber florr adhesive and secret nail 4.10-15mm expansion gaps allowed around all room perimeters 5. the floor is then level sanded, fine sanded and sealed and then finished with 2 coats modified oil in a satin. Jarrah 80x19prime concrete slab sealer 15mm plywood underlay 50mm spikes bostik ultraset timber floor adhesive deliver to site $13 530 including GST Installation, Sand & Polish $6160 including gst Thank you so much any opinion appreciated Brigette Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 2Nov 20, 2009 9:02 pm It would help if people would add at least their State ... Also, you didn't say who (what kind/size of business) has provided this quote, eg. one man band, hubby&wife Co, medium floor supply&install firm, large firm ... ??? Here's my shot anyway - I think this is almost too good to be true (just from looking at the scope of work and $ figures and assuming they also supply all the timber and all other materials)! My signature is distracting people from my wise posts ... Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 3Nov 21, 2009 6:33 am oops sorry Lex didn't realise state would have a bearing...i'm in the southern highlands of NSW and it is i believe a 5th generation family business....cheers Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 4Nov 21, 2009 7:14 am Hey! Personally I think it's a little on the pricey side for 86 sqm. I obtained a quote for approx 100 sqm (spotted gum) for 19mm boards of varying lengths. Installation very similar to yours...slab sealed, boards fixed onto battens etc etc. Total cost (incl sanding and polishing) approx $18K Pix Built a (highly) modified Allcastle Maxworth 38.7 in Sydney. Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 5Nov 21, 2009 7:38 am nowitstime oops sorry Lex didn't realise state would have a bearing...i'm in the southern highlands of NSW and it is i believe a 5th generation family business....cheers Hmmmm, from what I gather, non-metro prices would be even dearer than those in big cities. Also, Sydney can be the most expensive for certain things, but it really depends on what it is - sometimes it's on the cheap side! Very messy and hard to compare ... Maybe timber floors are chaper non-metro ... Anyway, "prime grade 80mm on plywood" - there are 3 things here that are supposed to make this quote more on the expensive side (prime grade is obviously the dearest, 80mm is supposedly more expensive than 130mm, plywood installation is also supposedly more expensive than the batten installation). Normally, for Sydney, and not going by the cheapest quote, you'd be fairly safe to allow $100-$120 per m2, all inclusive-complete-done (sometimes even less, but depends on what exactly are you after, and varies between co's). So, 86x100 = 8600. Yours is about $70/m2, which I think is quite good (especially considering the 3 things). Unless jarrah is actually cheaper than other commonly installed species ... or unless non-metro is also cheaper in case of timber floors ... Plus, you get the benefit of knowing that this business has been there for 5 gen's, so probability says it should (should stay there for a bit ... Also, the smaller the area, the dearer it tends to be. Yeah, I think this is good. Just look at Pix's quote - works out a whopping $180 / m2 !! My signature is distracting people from my wise posts ... Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 7Nov 23, 2009 9:42 am Hey Pix, mine costs the same as yours for spotted gum, Im also in NSW. We used an individual not a large company. Im not sure how comparable it is Brigette as I dont know how much your boards would cost. Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 8Nov 23, 2009 10:58 am Lex Anyway, "prime grade 80mm on plywood" - there are 3 things here that are supposed to make this quote more on the expensive side (prime grade is obviously the dearest, 80mm is supposedly more expensive than 130mm. Unless jarrah is actually cheaper than other commonly installed species Jarrah is only available in select grade. 80mm boards are cheaper than 130mm boards and jarrah is one of the more expensive species due to limited logging Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 9Nov 23, 2009 11:11 am Dukekamaya Lex Anyway, "prime grade 80mm on plywood" - there are 3 things here that are supposed to make this quote more on the expensive side (prime grade is obviously the dearest, 80mm is supposedly more expensive than 130mm. Unless jarrah is actually cheaper than other commonly installed species Jarrah is only available in select grade. 80mm boards are cheaper than 130mm boards and jarrah is one of the more expensive species due to limited logging Great - more info coming in!! Although, another user also had the opposite experience with slim vs. wider boards - their wider boards were cheaper than the slimmer ones - check it out here: http://forum.homeone.com.au/viewtopic.php?f=31&t=19007&start=620 (quote: "... We went for the wide boards, mainly because the darling wife wanted them, and they were actually much cheaper than the 85mm. ..." end quote) It's hard to generalise , but at least nowitstime's quote for prime jarrah indeed seems to be veeerrryyy good ! My signature is distracting people from my wise posts ... Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 10Nov 23, 2009 1:05 pm I would question the details of that post. There may have been a special for the wider boards at the time which is quite common though I will say Boral DO NOT sell to the public (or builders etc) at all. Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 11Nov 23, 2009 2:40 pm $180 sq mtr Where you are coming from is where you are going to... Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 12Nov 23, 2009 2:52 pm onc_artisan $180 sq mtr Thats probably close to the money for supply, install and finishing. Select grade jarrah is around $75 sq. metre alone, then adding 15mm ply, install plus sanding and lacquering. Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 13Nov 23, 2009 7:11 pm Dunno ... but just remembered that I actually saw some Boral price list some time ago (when we were investigating). Found it (in my Favourites ) and here it is - this is only for WA, though, but perhaps it can help someone in getting some idea about the cost. http://www.midlandbrick.com.au/Brochures/orders/PDF/Timber%20Price%20List%20OCT09%20PROOF6.pdf?company=Midland Didn't read any fine print (or large, for that matter ) except for some prices, so not sure if you can just walk in and buy yourself. Here are the jarrah prices for those who won't download: Jarrah Natural grade Size $/Sqm 80x19 $37.45 130x19 $45.60 Jarrah Australiana (Std) Grade 80x19 $68.00 130x19 $73.25 Jarrah Classic grade 80x19 $80.05 130X19 $85.75 So, if you use a little bit of maths (and if I got mine correctly ), the 130 boards seem to work out cheaper from Boral. EDIT: ***cough*** Hang on, this is in sqm (NOT linear), so smaller boards are cheaper !! Maths was good, but the eyes weren't communication to the brain hehehehehhe My signature is distracting people from my wise posts ... Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 14Nov 23, 2009 7:54 pm the sq. metre prices in your list are clearly dearer for the 130mm boards Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 15Nov 24, 2009 7:02 am Yeah, yeah , I was looking at the "sqm" but thinking "linear" and by the time it flipped in my head, I was too lazy to go and delete the comment . Anyway, the original quote seems too good to be true, but looks like by now the original writer has lost the interest in this topic (or just reading it) ... anyhow, it's always good to get as many experiences (comments) as you can. I know I'll be (again!) interested in this in several months time ... so I'm keeping an eye on things like this and it's always good to generate some discussion ... Cheers My signature is distracting people from my wise posts ... Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 16Nov 24, 2009 12:20 pm No not lost interest..just processing all the comments.. Thanks everyone for the feedback Re: Need Expert Opinion on Timber Floor Quote?? Is it reasonable 17Nov 24, 2009 7:14 pm .....and we've been discussing it in private Seems good to me. I've been told $4-5k/sqm is reasonable in Perth. 2 11171 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6139 these look like missing batts. Go up and take a look. But yeah moisure meter is a completely different tool 4 9456 |
