Browse Forums Flooring & Floor Covering Re: Floor sanding - without drum sander? 2Oct 30, 2009 11:49 am Where you are coming from is where you are going to... Re: Floor sanding - without drum sander? 4Oct 30, 2009 1:13 pm Where you are coming from is where you are going to... Re: Floor sanding - without drum sander? 6Oct 30, 2009 1:41 pm Where you are coming from is where you are going to... Re: Floor sanding - without drum sander? 11Nov 04, 2009 1:11 pm Dukekamaya You will still have to add the cost of the floor finish and applicators etc to that $1700 saving Yea I did : ) Finish is around $150-180. Extras (safety gear, brushes, applicator) - $50. Managed to book a drum sander in this weekend (they got it couriered in). Re: Floor sanding - without drum sander? 12Aug 08, 2011 4:47 pm Arent these things only around $130 per day from kennards? http://www.kennards.com.au/index.php?fu ... hers&lvl=2 Re: Floor sanding - without drum sander? 13Aug 08, 2011 4:52 pm Most definately hire a sander, you will regret it if you go to all that expense of coatings and find that the gloss finish highlighted every little perfection you thought would not be seen. Been there done that, hire the sander. This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28290 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 20864 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 4997 |
