Garage floor - paint or epoxy
Our current home has a painted garage floor which peeled as soon as a hot tyre went over it - so it is patchy.
What is recommended for garages? Our builder mentioned an epoxy material which may require some work to put down. The area is 9m x 6.6m.
Any suggestions for a colour? Walls are a Dulux russian toffee.
Thanks.
From memory the colour range is somewhat limited and I'm not sure if it can be tinted.
They are applied as a "system" that might include (depending on the type of conrete) the need for hydrochloric acid etching of the surface to allow the paint to adhere correctly. Then there is a curing period. You can also add product (sand?) to the paint to improve the non-slip characteristics.
Lots of info available from the paint distributors. You will have to check them out and make a decision.
Judie
Not sure what is the best option yet
I used the oil based berger jet dry at the old place and it worked well.
And there are other products by other companies as mentioned but all others are oil based and require acid etching of the concrete, nothing i want to be spraying all over the walls of my garage.
1
isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest…
12/06/2023
CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.…
