Browse Forums Flooring & Floor Covering 1 Oct 13, 2009 1:20 pm Hi, have been reading up on this thread and It has helped me decide on SDN for my new carpet, but I want to get a few more specifics from you all out there....I see that there are many styles out there, what style is recommnended for a family. Its my bedrooms and my living room, don't want the walkways showing up too much, so what's the best style to go with?? Any further info I'm going to accept....cheers Re: More advice needed on SDN Carpet 2Oct 13, 2009 2:44 pm SDN Carpet is good for bedroom. You just put 2-layer carpets in bed room. Re: More advice needed on SDN Carpet 3Oct 15, 2009 5:11 pm Hi Vinnie, The market is pretty much saturated with lots of SDNs at the moment, and there are many varieties. They are often oversold, and although they can be great carpets, they don't necessarily perform as well as the sales blurb you will hear. If you go for SDN carpets, make sure the carpet specs say it is treated with a stain blocker/stain release finish. This helps the stain resistance. There are all sorts of styles. Cut, loop, sculpted cut & loop, sisal style etc, etc... They will perform better if they have some features that breaks up the appearance. Things like patterns in the texture make them much more forgiving. Avoid very plain, uniform or linear designs if you can. And mid-tones will be more forgiving than carpets that are too light or dark. Ash. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6889 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6996 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15661 |
