Sorry - another question about underlay
Thanks for any advice and again, sorry to be starting a new thread when there are many already.
Cheers, Lee
I did look at the underlay and it was Dunlop but l can't remember the exact one. The carpet layer (of 27 years experience) said that it is the 2nd best underlay....he also said that the for the 'best' one didn't provide much noticible more benefit for the extra $$, so much so that Floorworld (Wodonga anyway) don't even stock it.
Royal Blue....I don't remember seeing 'Excellay'...l'm positive it was two words. Is Excellay only what is known as? or is it a type of underlay which has different types of underlay in that range?...does that make sense??
http://www.dunlopflooring.com.au/Commer ... cellay.asp
The above is Excellay.
The usual Dunlop underlay supplied would be the Springtred range. http://www.dunlopflooring.com.au/Reside ... -Range.asp You probably had Springtred Extra laid.
Excellay is much better than any of the Springtred range.
Better underlays are dense and low profile = Excellay or Bridgestone PRIME.
Thicker softer underlays might appeal to you, but they are quite often more problematic. With a nice soft carpet, you can still enjoy the comfort you want.
Ash.
Ash.
Glad you're happy with your carpets. NOT wanting you be otherwise, but just thought I'd clarify some comments about Springtred underlays...
Sounds like you probably have Springtred Extra. The common consensus is this is a good quality domestic underlay offering a nice soft feel underfoot. It will probably give good service if the carpet was laid well.
My main concern (and why I keep saying a firm dense underlay is best) is that a softer underlay allows more movement. With each step, the carpet and underlay compresses and then relaxes. This 'trampolining' places extra stresses on edges and seams. Also if its not laid tight, the carpet can develop rucks & ripples.
Again, I'm not saying you will have these probs, but knowing of the potential means you can keep an eye on it. If you notice any puckering at edges, looseness or other issues, contact the contractor to have it restetched. Your warranty should cover this if needed.
Cheers!
Ash.
I understand that a soft underlay can cause movement and thus problems down the track ( l learn't that from this wonderful forum
As our carpet was laid with a power stretcher and architectural smooth edge, hopefully that will go a long way towards preventing rucks and rippling. I suppose only time will tell
Ash.
I'm looking forward to catching up with you on the Gold Coast next week.
Ash.
I wouldn't scrimp with cheaper underlay.
Imagine our surprise/anger when some of the carpet has had to be pulled up and we notice they used black (basic) underlay!
why is it so hard to get honest tradies these days?? apologies to the honest ones but we are having a bad run
we have upgraded to Bridgestone gold underlay. Carpet was laid in a day when we werent at the house.
Suggest you go back to the retailer with contract in hand and demand you get what you paid for.
Ash.
its part of a home build and yes, we have told them to take up the carpet and put down the correct underlay,
cheers
Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many…
7/10/2023
1
Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon
22/01/2024
Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and…
