Browse Forums Flooring & Floor Covering Re: Cleaning concrete floor before carpet laid 2Sep 18, 2009 7:04 pm This is a good question Pisces. I was wondering the same thing. We recently had our carpet laid, and I don't think I paid enough attention to what they were doing. So I'm not even sure whether they claened the dusty concrete floor beforehand? What are other's experiences? Were they supposed to? Re: Cleaning concrete floor before carpet laid 3Sep 18, 2009 7:07 pm In our last house we replaced some carpet so I vacuumed the concrete prior. In the current house it was done through the builder, but we snuck in and swept the floors first. I would have preferred to vac aswell but couldn't. Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: Cleaning concrete floor before carpet laid 4Sep 18, 2009 9:48 pm If you need to.. You can hire a floor sander... It takes a big round sanding disc But this will take of all gyprock glue and bog and make it smoother. Where you are coming from is where you are going to... Re: Cleaning concrete floor before carpet laid 5Sep 19, 2009 12:44 am Pisces, New house or are you replacing older carpets? Firstly, make sure floor is smooth and flat. No lumps & bumps or holes. A good layer would check this (but don't count on it). It must also be dry. Often new houses have pads that are not properly dried within Standards. Of course it should be clean. Good to see you giving attention to it. Most layers won't! A good vacuum is a start. A mop over with a good disinfectant that leaves no residues is a good move, (but it must dry off for a few hours before carpets are laid). I'd use Whiteley Viraclean. Google it. Ash. I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 6985 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 3613 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 3375 |
