Browse Forums Flooring & Floor Covering 1 Apr 17, 2010 1:41 am Hi there, has anyone had any experience installing Quick-Step laminate flooring on their own? If so, I'd love to hear all about it....am thinking of installing ourselves but feeling very nervous about it. Not sure how easy it is and am afraid if it turns out looking not that great because am a NEWBIE at installing laminate flooring eventhough they are meant to be installed DIY. Re: Quick-Step 2Apr 17, 2010 6:33 pm ![]() Hi there, has anyone had any experience installing Quick-Step laminate flooring on their own? If so, I'd love to hear all about it....am thinking of installing ourselves but feeling very nervous about it. Not sure how easy it is and am afraid if it turns out looking not that great because am a NEWBIE at installing laminate flooring eventhough they are meant to be installed DIY. Not as easy as they say most people dont do such a good job and often i get calls to help finish it off. Re: Quick-Step 3Apr 17, 2010 7:15 pm Second that one mickve. You can usually pick a DIY job by the finish at door jams, junctions,and stagger of planks. Also the fitting of uniclic planks can be tricky, as they have to be clicked-in in both directions. Length and ends. One way is click length and then tap into the end. But peaking on the ends can easily happen if hit too much. Or cut, then fit entire row with just the side click. this usually a 2 person job if the runs are long. At jams etc you can't do it that way. Quicker and no tapping, or damage, of the main body planks is done by fitting end plank and lifting and pulling into side plank. That is an art that come with experience. the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12935 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 2304 Take a pick with a level sittingo n the slab and a pick with a level sitting on the sill please. This will help us diagnose the issue and therefore a solution. RE,… 8 11625 |
