Browse Forums Flooring & Floor Covering 1 Aug 29, 2009 8:19 pm Hi everyone, Went searching today to find a floating floorboard product for my unit. Initally saw Boral Silkwood and Premium ReadyFlor. But was won over by a product called Embelton. It comes with a slight bevel which distinguishes each 'floorboard'. However i've not seen it in many places - nor does a Google search come up with much information. It also doesn't help when there wbesite http://www.embelton.com.au is currently inaccessible. Just wondering if anyone out there has used this product, or sells this product, and can vouch for it?? cheers brad Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16031 As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 18093 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18359 |
