Browse Forums Flooring & Floor Covering 1 Aug 26, 2009 12:35 pm Does anyone have any info on "Australian Standard AS 3600 – 2001: Concrete structures"? I'm in the process of getting my floors done, and the floor layer has shown me how uneven my slab is. I'm trying to find out the standard/tolerances so I can go back to the builder and get them to pay for the levelling. It's just one thing after the other ... Judie Re: Slab not flat 2Aug 29, 2009 12:14 am Not sure of the specs, but a perfectly flat slab is as rare as hens teeth. Some variation is commonplace. I can quote the standard for sub-floor level requirements beneath carpets, which is going to be less critical than the floor beneath a polished porcelain floor. The tolerances will depend on what floor is being installed. Ash. Re: Slab not flat 3Aug 29, 2009 8:07 pm From memory it's about 95%, i.e a 5% tolerance in a 1m2 area. if it is then the slab shouldn't vary more than 5mm(5%)(100mm thick slab) in height in a 1m2 area I would check that though with the appropriate standard. A friend had a similar issue but with a sloping slab many moons ago, which is why i remember that figure. Re: Slab not flat 4Aug 30, 2009 3:51 pm The standards state that the levelness of timber and concrete floors except where documented otherwise, "new floors are defective if within the 1st 24 months they differ in level by more than 10mm in any room or area, or more than 4mm in any 2m length. The overall deviation of floor level to entire building footprint shall not exceed 20mm." Hope this helps you judie Dirk I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4114 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13890 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7222 |
