Browse Forums Flooring & Floor Covering Re: Good Tiler in SA ? 2Aug 24, 2009 11:01 pm When do you need one? Cause when I am done with my tiler I am happy to share, but first I will ask if it is ok to give out his number. Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7020 9 24636 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7235 |
