Browse Forums Flooring & Floor Covering 1 Aug 08, 2009 12:56 pm Hi All, Just getting some quotes for the Timber flooring,( not click clack) Approx 123 m2 and it ranges from $115-$175 this sounds like a lot of $$$ & What is the average that people pay, or is someone having a lend! I know that the slab would be the cheaper option, - would prefer to have Floorboards in QLD Re: Timber Flooring Costs - is this right? 2Aug 08, 2009 3:27 pm Are we talking about solid timber or engineered flooring. also, is it directly on slab, on battens or on plywood? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Timber Flooring Costs - is this right? 3Aug 08, 2009 4:26 pm Hi Casa2 They are solid timber, highest quote Forest Red Gum (select grade) moving down to Yellow Tongue, the floors will be on battens, ( house will be on stumps). and the quote is for the whole house including kitchen, bathroom, laundry, I am still looking at floor tiles in bathrooms. thanks Believe Re: Timber Flooring Costs - is this right? 4Aug 08, 2009 5:59 pm I've been quoted $160/m2 for Sydney Blue Gum Select Grade Slimwood on 12 mm plywood. So your quotes sound about right. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Timber Flooring Costs - is this right? 5Aug 08, 2009 6:29 pm Your looking at about $80 sq. metre for Forest Red Gum (aka Qld. Blue Gum) in 80x19mm select grade. Yellow tongue is about $36 per sheet (3600x900mm) and hardwood floor battens about $1.50 per metre and they need to be laid at 450mm centres Re: Timber Flooring Costs - is this right? 6Aug 08, 2009 7:44 pm Dukekamaya Your looking at about $80 sq. metre for Forest Red Gum (aka Qld. Blue Gum) in 80x19mm select grade. Yellow tongue is about $36 per sheet (3600x900mm) and hardwood floor battens about $1.50 per metre and they need to be laid at 450mm centres What about laying labour and sanding and polishing? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Timber Flooring Costs - is this right? 7Aug 08, 2009 8:43 pm sanding and polishing is about $25-$30 sq. metre. There are too many variables in laying to have a figure. it varies from site to site. Re: Timber Flooring Costs - is this right? 8Aug 09, 2009 6:12 am Hi, So the quote, if I am reading it right, includes sanding and polishing, I got the quote from the builder, but really did not ask if it included sanding and polishing, but next when I speak to him I will clarify, that is does. Thanks for your answers, I feel a little better for now! B Re: Timber Flooring Costs - is this right? 9Aug 19, 2009 3:30 pm We are gettting overlay timber floors which is exactly the same as soild timber except its a bit thinner to go over the top of existing floors. Now we are getting messmate which we have been quoted about $48 per sqm. How much per sqm should we allow for installation, sanding and polishing? Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17543 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5892 |
