Browse Forums Flooring & Floor Covering 1 Jul 22, 2009 4:21 pm Need help with a new floor! We are wanting to replace our 70s brown slate, and are leaning towards a timber laminate in Smoke Cedar. Has anyone used this with success? Also need paint and carpet colours to match - we like whites, greys, blacks, silvers - no browns! THANKS in advance Re: New floor 2Jul 22, 2009 6:57 pm You will probably need to give the manufacturers name and range for someone to give a review of the product. I know very little on engineered flooring types/ ranges so can't help you unfortunately. Re: New floor 3Jul 23, 2009 7:37 am Thanks! You can tell, I'm new at this whole renovating caper. The floor sample I have is Formica Laminate, 12mm Grade in Smoke Cedar. Apparently a thicker grade than others. It has a rubber type underlay on the back. http://www.formica.com.au/step2.aspx Thanks appreciate your help! CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16850 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17708 6 55718 |
