Browse Forums Flooring & Floor Covering 1 Jul 12, 2009 8:58 pm Have just done a ball park calc for supply of timber floor for our house (we are OB's). $14k. We are checking out laying it ourselves. Has anyone laid their own timber flooring? Any tips to pass on? TIA HH Life's too short too drink bad wine Re: Fallen Over on the Floor :-) 3Jul 12, 2009 9:04 pm We have yellow tongue down, so will need to sand the joints first. Looking at about 174m2. Life's too short too drink bad wine Re: Fallen Over on the Floor :-) 4Jul 12, 2009 9:08 pm Start in the smallest most insegnificant section possible you will be an expert by the finish Go look at how they finish in the display homes, then checkout the flooring display centres. Where you are coming from is where you are going to... Re: Fallen Over on the Floor :-) 5Jul 12, 2009 9:15 pm You need to start from one side of the house and move in a uniform line to the other side of the house. Laying timber flooring can be done by anyone just takes time. To get my flooring to a standard i was happy with it took about 6 days (2 two people) to lay a little over a 100m2. It it wasnt my floor i could have done it in less time. You will need the follwing. Good drop saw Secret nailer and compressor Also a fixing gun with 40mm nails come in handy to get into places the secret nailer cant. Stanley knife to cut plastic if required Chisel or Metal bar to clo0se up butt joints. Hammer measuring tape Chalk line Re: Fallen Over on the Floor :-) 6Jul 13, 2009 6:58 am Thanks Borg. We have a central hallway that leads into our open plan living area. I was going to start there as that is where the longest runs would be. Life's too short too drink bad wine Re: Fallen Over on the Floor :-) 7Jul 13, 2009 8:36 am with tonge and grove flooring you cant always start in the hallway. You can only go left or right depending on which way the tougne is facing. If you hallyway is on the furtherst part of the house and you only need to lay timber on one of the sides then all is good. To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 412 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17527 |
