Browse Forums Flooring & Floor Covering 1 Jul 07, 2009 1:42 pm i'm just bought over 100sqm of boral coastal blackbutt solid select grade, 85mm by 19mm and i am now after someone to installed it. 2 i've been quoted $60 for sanding (4 times) and 2 layers of oil). and $165 per sqm for the stairs. secret nail and glue 2nd floor Does this sound reasonable? can anyone else recommend me an installer? any help would be appreciated thanks Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16021 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8361 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6207 |
