Browse Forums Flooring & Floor Covering 1 Jun 28, 2009 9:19 pm Hello, I got a problem and couldn't think of a solution. I have just installed the plywood on concrete today and realized that it is already higher than the kitchen and bathroom areas which are covered with tiles. With the timber (solid 19 mm), the timber floor with be approximately 25 mm higher than the tiled kitchen floor. Please let me know what to do in this situation. appreciate any inputs. Luke Re: transition from timber to wet area 2Jun 28, 2009 9:30 pm Hand rails for the step,,,, rip up the tiles and continue the timber Where you are coming from is where you are going to... Re: transition from timber to wet area 4Jun 28, 2009 11:02 pm ... and that Where you are coming from is where you are going to... CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16537 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3657 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15887 |
