Browse Forums Flooring & Floor Covering 1 Jun 13, 2009 5:38 pm Despite well meaning people trying to steer me away from polished concrete I am still very keen. I spoke to the builder yesterday about having the floor in my walk-in shower done in polished concrete. He said that may not be possible because you need to have a wet-seal between the shower base and the wall tiles. Can it be done? Brian Re: Polished Concrete shower 2Jun 13, 2009 6:23 pm I saw it in a display home a few years ago. I did wonder about the waterproofing but don't recall getting an answer. IMO there are enough problems with showers without asking builders to do something they haven't done before, but perhaps if you can get adequate information about how it's done or find someone who has experience in doing it you might want to go ahead with it. I think you would probably also need to look into non-slip coatings. You can see a pic of the bathroom here. http://www.allhomes.com.au/ah/ah0078?li ... pid=226147 These are the details of the display village. http://www.actewagl.com.au/eco-living/default.aspx Re: Polished Concrete shower 4Jun 14, 2009 9:12 am We do a lot of shower bases using the same process as the rest of the floors (using no coatings). You do need to get the water proofing correct, this involves planning ahead and putting in a membrane. It isn't that difficult to do, you just need to plan for it. You also need to make sure that the concretor gets the falls correctly to the drain (personally we prefer the trough drains). Regards, Ben Vander Veen PROGRIND AUSTRALIA Maintenance Free Polished Concrete, without coatings! www.progrind.com.au Re: Polished Concrete shower 5Jun 14, 2009 12:07 pm Ben, that sounds encouraging. I've given the builder your details. If he gives you or Danny a call we should be able to work something out. Brian I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9570 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5854 |
