Browse Forums Flooring & Floor Covering Re: Cost for laying solid wood flooring 4May 10, 2009 7:25 pm there are too many variables, you really need to get soeone out to quote Re: Cost for laying solid wood flooring 6May 10, 2009 10:34 pm I'd say around $40 per sq. metre including laying sheet flooring under. Re: Cost for laying solid wood flooring 8May 11, 2009 9:55 am That is a very reasonable price. If installers are around about that price here in Qld I will be going for timber I think now. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Cost for laying solid wood flooring 12May 12, 2009 8:13 am We have been quoted for installation only is $25 per square metre. To sand, varnish and polish will be another $25 so that is $50 per square metre installed, sanded, varnished and polished. All you need to do is supply the wood and underlay. This was the average quote price when I rang around here in Melbourne. Some were about $5 dearer. Re: Cost for laying solid wood flooring 15May 12, 2009 12:27 pm Also need to find out what material they are using for a vapour/moisture barrier: is it plastic or is it chemical ?????? This will change the price alot aswell. Will also depend on what glue they use, for direct stick you can't go past Bostik Instant Pro or as its known now as Ultraset. Are they secret nailing aswell (highly recommend) All i say is do your homework and you shouldn't be disappointed Ben LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD Re: Cost for laying solid wood flooring 16May 12, 2009 9:39 pm cheetah wow thats less than i thought, would that include it sealed and varnished? No that was a guesstimate for laying only. As buildersedge said you really need to sort out the details I think sanding/sealing is around $25-$30 sq. metre. Re: Cost for laying solid wood flooring 17May 12, 2009 10:39 pm Dukekamaya I'd say around $40 per sq. metre including laying sheet flooring under. I was (rough) quoted $170 - $220 m2 fully laid for blackbutt select grade - looking at 100m2 fancy a road trip to the sunny coast in January to supply and install at $40/m? ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: Cost for laying solid wood flooring 18May 13, 2009 8:07 pm serge44 Dukekamaya I'd say around $40 per sq. metre including laying sheet flooring under. I was (rough) quoted $170 - $220 m2 fully laid for blackbutt select grade - looking at 100m2 fancy a road trip to the sunny coast in January to supply and install at $40/m? The subject is "LAYING A SOLID WOOD FLOOR" - not supply and laying a floor - I never mentioned supply. At the moment you would be looking at about $38 sq. metre for feature, $53 for standard and about $69 for select in 80mmx19mm Re: Cost for laying solid wood flooring 19May 13, 2009 8:33 pm well that spoilt that ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15884 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8282 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1920 |
