Browse Forums Flooring & Floor Covering 1 Apr 25, 2009 9:04 pm Hi All, Just wondering whether anyone has experience with height allowances for Solid Timber floors. This is what I have been told by a timber floor company. Note: The timber floors which we are looking at are 18-19mm with a 19mm batten for ground floor, 1st floor it will be glued onto the particle board. 1. Ask Builder to have a helicopter finish for the concrete slab to allow a more even smoother finish. 2. Ground Floor - allow 38mm height over slab for Skirtings, Architraves, Doors, Kitchen, Staircase and only tack on skirtings to allow floor installer to adjust if necessary and re-nail in place. 3. 1st Floor - allow 19mm and rest is same as above. MadCow Re: Solid Timber Floors - height allowances 3Apr 27, 2009 7:57 am The minimum for 19mm floors would be 34mm as they must be laid over 15mm ply minimum or 19 mm battens. The 19mm floorboards should be mechanically fixed as well as glued. Re: Solid Timber Floors - height allowances 4Apr 27, 2009 2:33 pm Which is the better method of installation? I hear Baten is good as it allows some air circulation underneath the floor boards, however they may move over time if it is not anchored properly. Plywood seems a little bit dearer about $3-5 more per Sqm but doesn't have the air-circulation and will the plywood rot underneath if it is exposed to water? I guess you will get different sounds coming out of Baten and Plywood too. Would love to hear your comments and recommendation. MadCow Re: Solid Timber Floors - height allowances 5Apr 27, 2009 7:40 pm Plywood is generally seen as a better method as the battens can give a 'drummy' sound to the floor. You wouldn't really get air 'circulation' in an enclosed 19mm space 400mm between battens. The plywood would need some serious water soaking to rot it. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15907 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 2 4680 |
