Browse Forums Flooring & Floor Covering 1 Apr 23, 2009 10:16 am Tiler has put a few expansion joints on the top level tiled area, only problem is the silicon he used is a very different colour to the grout and it stands out like dogs things I have seen tiles that have "popped" because of no expansion joints and it's not good, but the darker colour is bugging me no end Re: Tile Expansion Joints 2Apr 23, 2009 7:10 pm Can you post some pics SuH? Why would they use a dark colour silicone? That sounds like someone was just being too lazy to get it right. If we tile we were told we need at least 3mm expansion room around the edge so I'm worried how that's going to look. Re: Tile Expansion Joints 3Apr 23, 2009 7:16 pm JellyLegs Can you post some pics SuH? Why would they use a dark colour silicone? That sounds like someone was just being too lazy to get it right. If we tile we were told we need at least 3mm expansion room around the edge so I'm worried how that's going to look. Well he used a light grey silicone which is the same colour as the grout, but the grout dries a lot lighter, silicone stays the same colour. I will do a photo on the weekend. He is a good tiler but it's annoying because it stands out. We have to have the silicone around the edge as well but hopefully it won't be as noticeable as right down the middle of the room. Re: Tile Expansion Joints 4Apr 23, 2009 8:41 pm Here's ours Suh, (pic take while house was being built, not my mess! ) our silicon is actually lighter than the grout though. I don't notice it anymore... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Tile Expansion Joints 6Apr 24, 2009 2:54 pm SuH Thanks donuts, do you have any running through the middle of the floor no! only at the joins/corners! is tiled only in wet areas, so not big areas. yours are going thru the middle of the floor?!! "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Tile Expansion Joints 7Apr 24, 2009 8:43 pm donuts SuH Thanks donuts, do you have any running through the middle of the floor no! only at the joins/corners! is tiled only in wet areas, so not big areas. yours are going thru the middle of the floor?!! Yes...one at each end of the room and each side of the island bench, which isn't very noticeable. I will take some photos tomorrow and show you. Furniture may hide most of it. Re: Tile Expansion Joints 8Apr 25, 2009 4:08 pm After another look I asked the tiler to remove the offending silicon and look for a lighter colour, and as he was going to put the light grey (which isn't that light) all around the edges I asked him to use off white so it would blend with the walls rather than trying to match the tiles. Does this make sense? Is it a good idea, of course it is Re: Tile Expansion Joints 9Apr 25, 2009 7:42 pm You can get a range of coloured silicones from Ardex or Dunlop. Ardex is the better professional quality stuff. Dunlop is the 'Bunnings' quality, although they are the same company. Find an Ardex supplier from the Ardex site here http://www.ardexaustralia.com/product_d ... 26&catid=5 The tiler should have chosen a matching colour. He probably just used what he had. He should now remove the old and install the right colour. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Tile Expansion Joints 10Apr 26, 2009 10:30 am Thanks Michelle, he said he used light grey silicon to match the light grey grout...BUT the grout has dried a very very light grey, and the silicon doens't dry any differently, there is no way I am settling for what he has done and he knows it now Re: Tile Expansion Joints 18Apr 28, 2009 5:17 pm Oh what a great example of what not to do Does he cough a lot at smoko and lunch? Where you are coming from is where you are going to... Re: Tile Expansion Joints 19Apr 29, 2009 9:31 am onc_artisan Oh what a great example of what not to do Does he cough a lot at smoko and lunch? just a young guy, very nice, very confident...he did a great job with the laying etc, but blind freddy would know that wasn't on. I'll pick it out myself if I have to. Re: Tile Expansion Joints 20May 12, 2009 5:13 pm Hi SuH, I'm wondering how you got on with your expansion joint - were you able to get it fixed? Our tiler has said he will be doing ours through the middle of the floor - now I'm NERVOUS! He's done a pretty good job with everything else, so fingers crossed he gets that right. Hi All, First time poster. I was hoping to get some advice on villaboard installation within a bathroom. I have installed villaboard before, in a laundry. I think I did… 0 7465 Looking for advice on whether this variation in tile colour is acceptable. The large tile on the left was used in my main bathroom renovation 1 year ago. My ensuite… 0 8490 Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6493 |
