Browse Forums Flooring & Floor Covering 1 Mar 26, 2009 8:16 pm Anyone has experience with low cost laminate timber floor(e.g. http://www.bigbrands.com.au)? I start to browse around for timber flooring and found that this so called german technology laminate timber come at an attractive prices($12 - 14 per sqm). But now wonder whether the quality and durability will be as any other laminate timber floor sold at $30 - 35 per sqm. Re: What's wrong with low cost Laminate timber flooring? 2Mar 27, 2009 5:41 pm the cheap stuff is often veneer over an MDF base. MDF does not like water so you will have trouble if used in kitchen areas etc. where spills occur Re: What's wrong with low cost Laminate timber flooring? 3Mar 27, 2009 5:43 pm Dukekamaya the cheap stuff is often veneer over an MDF base. MDF does not like water so you will have trouble if used in kitchen areas etc. where spills occur Not only that…the pattern or the top wears off after a while. Looks very nasty. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: What's wrong with low cost Laminate timber flooring? 6Mar 27, 2009 6:49 pm Yev_ What about installing laminate in bedrooms? It is not an extensively used area. Or better not to bother with laminate at all? You can use Laminates…..just not the really cheap ones. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: What's wrong with low cost Laminate timber flooring? 7Mar 27, 2009 6:59 pm My sister has them... A bit noisy I think..so far no wear marks 5 yrs Where you are coming from is where you are going to... Re: What's wrong with low cost Laminate timber flooring? 8Mar 28, 2009 8:22 pm We brought lamiate flooring about 6yrs ago and payed about $22sqm and layed it ourselves, but we only have it in the lounge room. So far nothings wrong with it and we have one big and one small dog running through the house too My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: What's wrong with low cost Laminate timber flooring? 9Mar 29, 2009 12:39 pm Laminate Flooring nowadays are made of HDF, what is yours camyperth? onc_artisan, is your sister also bought them from bigbrands? Re: What's wrong with low cost Laminate timber flooring? 10Mar 29, 2009 1:28 pm Yes mine is on hdf, domestic use warranty is 10 yrs called quickstyle made by wesfi My building thread viewtopic.php?f=1&t=25279 NEARLY DONE. KEYS ON 5/11 AT 1PM Re: What's wrong with low cost Laminate timber flooring? 11Apr 06, 2009 6:15 pm Have laminate flooring in my current home, my main issue is the noise. Even though we used the underlay recommended by the installer, it still makes a hollow 'clip clop' noise as you walk over it. Another issue I have is that there seems to be high spots where I can feel the floor give under me as I walk on it. But then again, it could be my imagination, as my wife keeps telling me! Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15919 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4932 4 6201 |
