I'm setting up renovated downstairs longe that will double as a home theatre. the floor is currently tiles, hence for audio purposes I'll need to opt for a thich floor covering. Should I consider a large rug or partially covering the floor with carpet?
What are the pros and cons??? The corner needing a covering is away from all doors, so perhaps carpeting atop the tiles, and putting in a metallic progression into the carpet is the way to go...
The high traffic areas around that corner will remain uncovered tiles.
MikeG
