Browse Forums Flooring & Floor Covering 1 Mar 17, 2009 3:33 pm Hi all,
We are building with Carlisle and getting grumpy with their lack of flexibility. We are doing the timber floor ourselves after handover - this was done not just to save builder markup but because Carlisle only offers laminate flooring and we wanted a better quality floor than that. Our site supervisor was very good and said he could have the skirting boards all cut to size and mark them for where they would go but when it came to formalising that he got overruled by his boss. It is saving them work so why they won't do it I don't know. So we are left with 2 options - leave the skirting boards off entirely and they will just be lengths of board - not cut to size, not painted or prepared in any way - and of course no credit for the less work. Or we can put them on and then use quad moulding round the edge of the rooms to cover up the gap where the timber boards butt up to the skirting boards. Can anyone share any photos of what it will look like with the quad moulding up next to the skirting boards. Seeing some photos will help us decide what to do - I am guessing it would be quite an expensive job to put the skirtings on, cut to size, paint them etc after the floors are finished. Thanks, Dale. Building the Monaco 32 with Carlisle Homes Check out our blog for photos and progress reports: http://www.beigefreehouse.blogspot.com . Re: Timber floor after skirtings have gone on - share your photo 2Mar 17, 2009 3:47 pm Check out this thread - https://forum.homeone.com.au/viewtopic.p ... 709#171709
I think the best approach is to have your skirting higher with allowance for the raised floor height, so the floor guy can just cut into the skirting without needing to remove and reinstall. Building Clarendon Brighton - Done and moved in Sept 2009 Re: Timber floor after skirtings have gone on - share your photo 3Mar 18, 2009 8:51 am Thanks for the link.
Does anyone have photos of quad after flooring? Thanks, Dale. Building the Monaco 32 with Carlisle Homes Check out our blog for photos and progress reports: http://www.beigefreehouse.blogspot.com . Re: Timber floor after skirtings have gone on - share your photo 4Mar 24, 2009 10:19 pm Scotia is much more commonly used for covering the gap rather than quad. If you paint the full lengths yourself and then just get a chippie in for the day it wouldn't set you back that much. You woould just have to touch up the fix-out nail holes. If your going the scotia/quad way, check what skirting they use, many project home builders use tiny little skirting (often 42x12 or 66x12 pencil round) - you don't want the scotia or quad to look as big as the skirting itself. Re: Timber floor after skirtings have gone on - share your photo 5Mar 25, 2009 7:16 pm i agree it's going to depend on the size of the skirting so if you have tiny skirting then finishing with quad will look a bit silly, but if the skirting is a nice height then quad will look fine and if you look at older houses with timber floors they all had quad laid. personally i like quad because i just think it finishes the skirting off nicely but not with tiny skirtings. Re: Timber floor after skirtings have gone on - share your photo 6Mar 27, 2009 1:56 pm This is laminate, not real timber, but we had the same issue with the builder not wanting to leave off the skirtings, so trim strips it was. We went for a triangular profile, which matches the skirting profile well in our case. The timber trims aren't even noticeable, unless you're looking for them. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ http://i68.photobucket.com/albums/i18/kerrynw/IMG_4676_1_1.jpg We'd already upgraded our skirtings to 92mm, which was just as well, as it turned out. Re: Timber floor after skirtings have gone on - share your photo 7Mar 27, 2009 7:42 pm kek, nice & tidy installation, would you mind share,what type of laminate you have? Re: Timber floor after skirtings have gone on - share your photo 8Mar 27, 2009 7:46 pm Dale, that is SO weird that CH didnt agree to leting the SS cut the skirting to size and labeling them. I'm at tender stage and i asked this same question and they told me that there is no problems with leaving the skirtings off and cutting it to size for us. They will tell our ss when we start construction! Idiots are fun, that's why there is one in every village! - Dr. House - Re: Timber floor after skirtings have gone on - share your photo 9Mar 27, 2009 8:47 pm I've heard if you paint the quad before you have it put on, in the same colour as the skirting boards, then they can look like they are part of the skirting board... like just another little ridge. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Timber floor after skirtings have gone on - share your photo 10Mar 27, 2009 9:09 pm Thanks for the photos Kek - they look good. Unfortunately we didn't think to increase the size of our skirting... Wonderland - I know, a real pain. Particularly after the SS agreed and then he got over ruled. So make sure you have it in writing if they have agreed to it now - or else you risk the same over rule! Donuts - thanks. I am thinking that painting the same as skirting might be good. We shall have to try paint and stain sample and see what seems to look best. The other thing is our walls will be white - although a different white to skirtings - so hopefully the 'smallish' skirtings will be less obvious. Jo Settled In - Home Search and Relocation Services - http://www.settledin.com.au http://www.movingbacktotassie.blogspot.com/ viewtopic.php?t=9571 Re: Timber floor after skirtings have gone on - share your photo 11Mar 28, 2009 3:13 am on the old timber floors quad and scotia were a necessary feature but these days with concrete floors underneath they are in most cases redundant, but i do think it gives a timber floor more of an authentic look. kek obviously wanted hers to blend in with the floor but i wouldnt have had any problem painting them and making them part of the skirting either which is commonly what was done. Some of these older features gave houses a lot of character so dont be afraid of them or feel you have to hide them. Re: Timber floor after skirtings have gone on - share your photo 12Mar 28, 2009 10:45 am Jo, so there is nothing that you can do now? Cant you go back to head office and tell them that because they are doing it for one client, shouldnt they do it for all? This must be so frustrating for you! Thanks for the advise, lucky for me, i emailed them to ask and they responded via email so its in writing and set in stone! Idiots are fun, that's why there is one in every village! - Dr. House - Re: Timber floor after skirtings have gone on - share your photo 13Mar 28, 2009 7:07 pm That's great Wonderland - you might need that email down the track! Our skirtings are now on. We met with SS just before they were due to go on, so only had a couple of days to work out what we wanted. OK about it now, will be fine. There will be lots of wonderful features in the house, so I hope I don't spend a lot of time looking at skirtings and quad! Jo Settled In - Home Search and Relocation Services - http://www.settledin.com.au http://www.movingbacktotassie.blogspot.com/ viewtopic.php?t=9571 Re: Timber floor after skirtings have gone on - share your photo 14Mar 28, 2009 7:16 pm Oh gawd, with the way your house is turning out, you will be too busy mesmerised by your bi-fold unit, kitchen, flooring, tiling etc to eve worry about the quad!!! Idiots are fun, that's why there is one in every village! - Dr. House - Re: Timber floor after skirtings have gone on - share your photo 15Mar 28, 2009 7:22 pm doghouse OK about it now, will be fine. There will be lots of wonderful features in the house, so I hope I don't spend a lot of time looking at skirtings and quad! no but all of these little things really do add to the character of a home, as in the bigger picture so dont worry, it will look nice Re: Timber floor after skirtings have gone on - share your photo 16Mar 29, 2009 12:36 pm These photos are from my sister's house, her quad is painted the same as the skirting. Looks fantastic. I didn't even know what a quad was until a year ago when she looked at some display homes with me. I had always assumed that it was all part of the skirting at her place. That made up my decision to paint our quads the same as our skirting rather than stain to match the floor. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Happy at Home Re: Timber floor after skirtings have gone on - share your photo 17Mar 29, 2009 12:48 pm Thanks HTB, that looks great. I hadn't seen it done before. My feeling was that it would probably look good and be my preference. Ta Jo Settled In - Home Search and Relocation Services - http://www.settledin.com.au http://www.movingbacktotassie.blogspot.com/ viewtopic.php?t=9571 Re: Timber floor after skirtings have gone on - share your photo 18Mar 29, 2009 9:51 pm Toni, that does look really good!! But it doesnt look like those typical triangle looking quads. I didnt know there are diff types of quads you can get. Def looks good painted the same colour as the skirting! Idiots are fun, that's why there is one in every village! - Dr. House - I already have the doors and architraves installed as pictured. My question is which size n type of skirting would go with the architraves? I originally wanted a winder,… 0 2905 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 1829 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 30559 |
