Browse Forums Flooring & Floor Covering 1 Mar 17, 2009 2:08 pm We have recently moved to Hobart and are having difficulty in locating retailers to supply a timber floor - most only stock the engineered timber products. We have not decided on a timber at this stage as we are waiting to see what is available.
Any recommendations? Thanks Re: Where to buy solid timber floors in Hobart 2Mar 17, 2009 6:30 pm Have you tried timber yards?
I imagine Gunns stuff is easy to get there Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15839 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8251 2 4657 |
