Browse Forums Flooring & Floor Covering 1 Mar 15, 2009 3:02 pm We are looking at timber flooring options for the new house we are building, and are currently trying to decide on plank on ply vs direct stick. We will either have Blackbutt or Australian Whites, wider boards, and 19m thick.
Question 1- any strong opinions on plank on ply vs direct stick? Question 2- if you go direct stick, is there nails involved, or just glue? We are not keen on the nailed look... Re: Timber floor questions 2Mar 15, 2009 3:35 pm I wouldn't direct stick wider boards for a start. They need to be top nailed in the 19mm thick profile. There is a 15mm overlay wide board that can be secret nailed
The jury is still out in the industry on the direct stick method as a whole as there is no way to mechanically fix the boards as there is with ply/battens etc. For every install with no problems there seem to be one with problems. having built in different rural locations may i suggest that the house should suit the location and needs to be different from homes in town..eg if you will be working… 9 5000 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15922 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3280 |
