Browse Forums Flooring & Floor Covering 1 Mar 10, 2009 5:17 pm OK, so I know what I should have done to prevent it, but how can I get rid of them? have tried vaccuuming & gently brushing with a stiff brush, but not much joy.
Any suggestions? Life's too short too drink bad wine Re: Furniture Indents On Carpet 4Mar 12, 2009 6:26 am Just a bit of moisture will normally do the trick.
Place a few drops of white vinegar in a cup full of water and place a teaspoon of water in the indent. Use a big toothed comb to gently lift up the pile to put it in the shape you want and the dent will sort it self out after a few hours. It will sometimes do it by itself in hot humid weather after a few days. cheers Col Nation For information on caring for wool and other carpet and upholstery go to www.woolsafe.com.au 1 11003 1 15753 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6581 |
