Browse Forums Flooring & Floor Covering 1 Mar 10, 2009 11:57 am Hey all, we are getting our vinyl planks installed this week and now I have to decide which way to run the planks. This is our plan.
edit... oops, I posted the wrong pic. sorry. this is the correct one Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I need to decide by thursday morning aaaahhhhh Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Re: Which direction for timber look flooring? 2Mar 10, 2009 12:46 pm We installed our floor boards in our current home so that they ran parrallel with the length of the room.
I'm not sure what extends beyond the kitchen area in that photo, but it might look good to run your boards parallel to the hallway walls to add length and make it flow nicer than if the boards ran "short" across the hallway?! Building a Wisdom Homes Impression 33 MkII http://lilypadintheponds.blogspot.com/ We have the keys! Tiling in progress... Re: Which direction for timber look flooring? 3Mar 10, 2009 1:00 pm Maybe I'm a bit of a tool - but I'd just run them as if they were built into the house..........i.e, if you had floor joists & floor boards. The joists would run the shortest span & the floor boards would be perpendicular to that.
So, if memory serves (which it generally doesn't) as the coral daydream is a deeper house than it is wide, I'd run them from the front to the back (the joists would run left to right). .........yep, definately a tool! Re: Which direction for timber look flooring? 4Mar 10, 2009 1:11 pm Hey seakyl, i'd recommend running them from the front door down the hallway to the back of the house. This is how ours are and it looks better than running them sideways across the house!
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It elongates the rooms somewhat and gives a sense of flow when entering the house IMO. Less wastage that way too! Good Luck with it! Make sure you post pics!!! Re: Which direction for timber look flooring? 5Mar 10, 2009 1:55 pm Absolutly agree with Phoenix!
I wouldn't run them any other way, I think it would look terrible, JMHO! We will be running them the same as Phoenix has. Can't wait! Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Which direction for timber look flooring? 7Mar 10, 2009 3:39 pm Wow Nic, is that your house? It looks amazing! Re: Which direction for timber look flooring? 8Mar 10, 2009 7:40 pm Thanks everyone for your replies. I was thinking of going this way to start with but the tiler suggested the other way. ..but I will definately be making the planks go towards the rear of the house.. Thanks
Phoenix... LOVE your timber floor.. looks excellent!!! Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31818 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4353 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15907 |
