Browse Forums Flooring & Floor Covering Re: What timber species is this?? 2Feb 26, 2009 9:51 am Impossible to tell from a terrible pic like that - could be blackbutt or something similar (i.e. ten other species) Re: What timber species is this?? 4Feb 26, 2009 11:56 am Apologies for the poor quality of the pic. I only came across this from the internet and quite like the colour.
I am just scratching my head on timber colour. The colour varies A LOT from different pics. See below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I like the colour in the second pic. But I don't want to get blackbutt that is so light, like the first! Even going into different showrooms, some blackbutt are light, some are darker. This is driving me crazy. Building Clarendon Brighton - Done and moved in Sept 2009 Re: What timber species is this?? 5Feb 26, 2009 4:54 pm Hi Echo
Its your lucky day I actually have the picture (cut from a magazine with two other pics of the same house). You can see the flooring very clearly. The colour of the wood is similar to blackbutt but its in short thin strips. I must admit it does have a laminate look to it but the house is a water front property so I doubt it is. I can send it to you if you like Mrs B Re: What timber species is this?? 6Feb 28, 2009 6:06 pm The second pic is more the colour of blackbutt with an oil based finish ( I have blackbutt with tung-oil)
The first pic is closer to blackbutt with a water-based finish Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15909 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6141 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3278 |
